11-01-2008, 12:39 AM | #1 |
Rep 893
DIY Rear Sway Help?
Hi guys I read through all 6 pages of posts for a DIY for the rear sway bar. I read countless post that it is a PITA but I did not find a DIY. Did I over look one? If some one could just posts a few hints I am going to give this a shot tomorrow I have a Blackberry and will try to take photos as I go. Wish me luck guys I hope it is not as hard as I have read.
2008 BMW 135i, DINAN / Riss Racing / BMS
10-18-2010, 09:30 AM | #2 |
Auto X'er
Rep 157
+1.... I would like to know as well. Any DIY's out there?
2009 135i SGM, Premium, Sports, Nav.
Dinan Stage 2 software, Injen intake, RR Oil Catch Can, H&R Pro-coilovers and springs, H&R front sway bar, Vorshlag camber plates, Vorshlag comp studs, BMW strut brace, BMW performance pedals, G-Force harneses, BMP tow hooks, Breyton GTS-R wheels with 255-35R18 (square set up) and custom axel back exhaust with muffler delete. |
06-22-2011, 09:34 AM | #3 |
Rep 1,406
Drives: 2020 SO - M2C
found a site not sure if its accurate or not..maybe someone who did the install could confirm?
http://www.eurotuner.com/techarticle...ate/index.html |
06-22-2011, 09:37 AM | #4 |
Rep 2,696
to do the rear sway you need to drop the rear subframe. Look for the DIY for the rear diff as it's on there.
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
06-22-2011, 09:42 AM | #5 |
Rep 1,406
06-25-2011, 02:46 AM | #6 |
Rep 3,456
Drives: Harrop E90 M3
You don't need to drop the subframe for a diff. Drop the exhaust to get it out of the way, there are 4 bolts for the subframe. Before you lower, you'll have to get some slack in the wheel speed sensor wires by removing them from the body mounting points. Also the brakes lines will need to be taken apart near the drivers front side of the subframe. Then you can lower the subframe. About 6" of drop will get you what you need to unbolt the bar and slide it out either side. But really a pia, but time consuming. You'll need a good jack to support the subframe and the car on jack stands unless you have lift access. Lift access is money in your project....
07-07-2011, 09:44 PM | #7 |
Rep 121
07-07-2011, 10:15 PM | #8 | |
AutoXer
34
Rep 683
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
08-26-2011, 05:32 AM | #9 |
Rep 1,473
I have a lift so this doesn't seem too difficult. However, I am wondering what type of jack you used to hold the rear axle?
08-26-2011, 10:07 AM | #10 | |
Rep 566
BTW - the article describes everything required for the rear bar install, notably: Crimp and disconnect two rear rubber brake lines (rear left) Unclip ABS wires running down the subframe Disconnect rear section of exhaust (allows you to drop subframe further, otherwise it stops when it rests on the exhaust, which might not be enough for you) Disconnect lower cross brace rear section (requires removal of the plastic mudflap trim to get at one of the bolts) Remove four subframe bolts with transmission jack in place
08-26-2011, 11:57 AM | #11 | |
Rep 1,473
I am not really intersted in completing this on my back so I will try to find something that reaches high enough. |
