      11-04-2008, 11:24 AM   #1
pkcormier
Drives: 135i
Disable Headlight Washers
Has anyone figured out how to disable the headlight washers?
      11-04-2008, 11:27 AM   #2
EspressoBoy
1addict, and proud
EspressoBoy's Avatar
Drives: BMW 135i 08
Just wondering, why would you want to?
I think if I am not mistaken, it will only come on when your headlight setting is in AUTO, switched to Manual, and they don't come on. Don't quote me, I am using my faulty memory, not the faulty manual.
LOL
EspressoBoy
      11-04-2008, 11:46 AM   #3
pkcormier
Drives: 135i
I live in Texas where I will never need to clean my headlights between car wash intervals. And the headlight washer makes a brilliant display of overspray. I keep my lights on Auto and will never remember to switch to manual when using the windshield washers. I'm too busy trying to remember how to get home.
      11-04-2008, 11:55 AM   #4
EspressoBoy
1addict, and proud
Drives: BMW 135i 08
LOL, that's why I have NAV, the car tells me where to go every day...
I love it when I miss the street and it sounds like "make an illegal tern" but it is really saying "make a legal tern".
Anyway, so it is true, leave it on manual and no wash then. That seems like a fair solution. I bet if you found the tube that goes to the pump, you could just disconect them.
EspressoBoy
      11-04-2008, 12:26 PM   #5
pit1
Drives: F87 M2
I'm not sure about the manual vs auto conditions...but the washers will ONLY activate when the headlights are ON. I THINK it's an On/Off thing rather than a Manual/Auto thing.
If I've just washed her and it's overcast or dusk, I'll briefly turn off the headlights while and pull the trigger and turn them back to auto after the spray. A bit of a problem, however, when you might just need those headlights.
      11-04-2008, 04:09 PM   #6
pkcormier
Drives: 135i
I leave my lights on auto and used the washer this am on the way to work. Bright daylight. Headlight washer blasted my lights leaving a shimmering reminder on my clean hood. Auto mode activates the daytime running lights. I wish there was a fuse dedicated to the washers. I will look for the hose leading to the washer nozzel and disconnect or pinch off. But I suspect it will be hard to reach without removing the bumper cover.
I do know that it does not activate the headlight washer each time. It is on an every 3rd or 4th cycle. At least that's better than my old Audi S4 which was every time.
      11-04-2008, 04:25 PM   #7
Haywood
I know a thing or 2 about a thing or 2...
Haywood's Avatar
3101
Drives: E36 M3 Coupe, e39 M5, i3s
2003 BMW e39 M5  [0.00]
1997 BMW e36 M3  [0.00]
Just so I understand, if you turn your switch to manual, you don't get the Daytime Running Lamps?
      11-04-2008, 07:23 PM   #8
gyrfalcon
Ninja
14
Drives: 135i
You will always have daytime running lamps on, regardless of switch position, if you have them enabled in either the left stalk menu or I-drive.
SGM/Coral
      11-04-2008, 08:38 PM   #9
EspressoBoy
1addict, and proud
Drives: BMW 135i 08
Originally Posted by gyrfalcon View Post
You will always have daytime running lamps on, regardless of switch position.
That might depend on which country. I know in Canada we have them, but not sure in USA. I think I remember someone saying they don't have that.
Correct me if I am wrong. (PM me)
EspressoBoy
      11-04-2008, 09:48 PM   #10
Addict...Nah Im A Junkie!
Addict...Nah Im A Junkie!'s Avatar
34
Drives: 09 135i, 98 M rdstr
Should I cut the blue wire first?
Or the red wire?
:iono:
'09 135i 6MT : Space Grey/Black ette : Cold Weather Package : Sport Package : Glacier Silver Aluminum Trim : iPod and USB : Nav : HD radio : Premium hi-fi system
      11-04-2008, 10:05 PM   #11
ben14142001
Drives: 2018 M3 ZCP
You can turn them off through the iDrive system.
-Ben
      11-05-2008, 09:12 AM   #12
pit1
Drives: F87 M2
You can also turn off DRLs with no iDrive, in left stalk options.
If your headlight washers are going off, it should ONLY be because your headlights are ON. I've also been driving in early morning daylight and my headlights were ON in Auto mode. IMO the sensor does an excellent job at managing the headlights. Even in direct sunrise/sunset lighting, the headlights are ON giving the necessary rear lighting.
Anyone know where the headlight sensor is?
      11-05-2008, 09:35 AM   #13
123D-M
123D-M's Avatar
Spain
32
Drives: BMW 123d M-Sport Coupe
It's in the windscreen. Next to the rain sensor.
2009 123D Coupe | Sedona Red | Black Boston Leather | Brushed Aluminium Trim | Tinted Windows | M-Sport Package | 6M | Comfort Access | Heated Seats | Navigation | Park Distance Front & Rear | USB | Bluetooth | Voice Control | Efficient Dynamics | Rain & Light Sensors | Xenon Lights
My blog: http://urbanemusings.wordpress.com/
      11-05-2008, 01:08 PM   #14
F31TanzBlue
F31TanzBlue's Avatar
Drives: BMW 340 F31
Head lamp washers activate when the headlights are on... so turn off the headlights completely including day time running.
      11-05-2008, 01:42 PM   #15
pkcormier
Drives: 135i
US spec 135i does not activate daytime running lights in the manual or Off position. Just in Auto mode.
I am looking for the lazy man solution, if there is one. I like the idea of daytime running lights and the convenience of never needing to decide when to turn on/off the headlights.
I think what I will do is take some duct tap and slap if over the washer covers.
      11-05-2008, 05:29 PM   #16
pkcormier
Drives: 135i
Exactly! The only time in my life I have ever needed to clean my headlights between washing my car was coming down the mountain at night from a ski weekend, and the dirty sludge on the road began to degrade my visibility. I pulled over and wiped them with a rag. Problem solved. Now I cross my fingers when I pull my washer lever that I am not on the headlight interval.
      11-05-2008, 08:51 PM   #17
SlapSmak
Drives:
8000 miles, I have never had my wipers on. RainX rules
98 Type R
      11-05-2008, 10:38 PM   #18
pkcormier
Drives: 135i
It's not an issue of rain. I just can't stand a dirty windshield. It only takes a day or so after washing my car for the windshield to get a thin layer of haze. A quick shot of washer fluid and a few swipes of the blades and I'm sane again. Now if I could just stop the headlight washers from spotting the hood and bumper. Duct tape didn't work.
      11-06-2008, 01:06 PM   #19
Berduderunner
drk one
Berduderunner's Avatar
Drives: 2008 135i
2008 e90 335i  [0.00]
2008 135i  [0.00]
AMEN.
Jet Black | Coral | HighGlossBlack | Steptronic | Premium | Sport | Comfort | ActiveSteering | Navi | HiFi | HD | iPod | SAT
BMS JB3 v2.0 | BMS DCI | Berk Tech Sport Exhaust | UR * DPs | CoolingMist Meth Kit w/ CMGS | H&R OE Sport Springs | Breyton GTS-R | Dunlop Direzza Sport Z1 Star Specs | GP Thunder 8000K Low Beams/Angel Eyes/Cornering Lights | LED Interior Light Kit | Window Tint | Smoked Tail Lights | Smoked License Plate Cover
      11-06-2008, 01:17 PM   #20
xbook
xbook's Avatar
Drives: '14 EBII M235i & '06 R53 GP
2006 MINI Cooper S GP  [0.00]
2014 BMW M235i  [0.00]
2008 E82  [0.00]
Or the red wire?
:iono:
NOT THE RED WIRE!!!!! Cut the green one, otherwise we're all gonna blow up!!!
      11-06-2008, 06:22 PM   #21
Qube
Drives: E39 540 :: 09 STi
+1. Always. New car, used car, friends car... Rain-x is the first thing to go on... then wax.
      11-06-2008, 07:21 PM   #22
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
Or the red wire?
:iono:
shoot the hostage
1addicts
