      11-10-2008, 06:17 PM   #1
modbargains
modbargains's Avatar
171
Drives: 08 E90 335i & 01 Toyota Avalon
**********s - Special Preorder Pricing | Cross Competition Coilovers
Hey Guys,
[IMG]http://www.**********s.com/images/Products/CROSS/aboutcross.jpg[/IMG]
We are proud to introduce Cross Competition Coilovers at a SPECIAL PREORDER PRICE for you 1Addicts members!
[IMG]http://www.**********s.com/zoom_img/_1221490243.jpg[/IMG]
The ultimate coilover setup for your "Ultimate Driving machine," JIC offers the bets with no compromises for your BMW with the Cross Competition Coilovers. The Competition Series is JIC's top of the line coilover system featuring a light weight design with a 15-way damp adjustable monotube shock. With its high strength build and durability, this ensures that they will last through the most harshest of driving conditions.
  • PILLOW BALL UPPER MOUNTS: Included for some vehicles for the front and some for rear depending on application. Adjustable camber plates also included for most vehicles front applications with MacPherson Strut suspension systems, some applications may come with a rubber bushing upper mount depending on application.
  • COOL BEND LINEAR SPRING: Linear (consistent spring rate) spring manufactured using chrome silicon metal alloy with a cool bend process to prevent sag or loss of spring rate. Each kit comes with various spring rates that are available for more of a custom set up.
  • HIGH STRENGTH INVERTED MONTOTUBE: This unique design features a 40 mm piston with a one of a kind bumpstop design incased inside the damper. The walls of the shock casing is lined with grease so that the absorber body can easily move along inside the shock casing body. There are also two thrust bearings to protect the absorber body.
  • HELPER SPRING: Select Cross Competition BMW coilovers come with helper springs to aid for street day to day driving. This also allows for a wider range of higher spring rates and for a smoother ride.
  • ADJUSTABLE DAMPENING: Available for all applications with 15 ways adjustability. With this feature, you are able to tune your suspension dampening up to your specifications and style of driving.
  • DURABLE MONOTUBE DESIGN: High pressure nitrogen gas filled monotube design with special stable viscosity index oil that will not be affected by wide temperature changes. Therefore, heat does not affect the performance capabilities. 40mm and 45mm pistons are used on certain applications.
  • ADJUSTABLE LOWER BRACKET: More durable than factory brackets with adjustable ride height ranging from 0.5" to 2.5" drop without sacrificing the suspension travel.
Benefits
  • Full damp adjustable
  • Full height adjustable
  • Custom spring rates available
  • High quality
  • High durabilty
  • Streetable
  • Trackable
  • 30 Day Limited Warranty on manufacturer defect.
Let me know if you have any additional questions that I could help answer. If you would like to contact me personally, you can always PM me or contact me via e-mail at Roger************.com.
      11-12-2008, 05:07 PM   #2
modbargains
171
All PMs replied!
      11-21-2008, 12:44 PM   #3
modbargains
171
Thanks for the orders guys!
      11-24-2008, 07:33 PM   #4
modbargains
171
PMs replied!
      11-26-2008, 05:53 PM   #5
HighQ
Quality is everything
HighQ's Avatar
Vietnam
12
Drives: you mad
I don't understand the warranty: is it 30 days full stop?
      12-10-2008, 02:16 PM   #6
modbargains
171
[IMG]http://www.**********s.com/images/Products/CROSS/1crosscoiloverenglishdetailWM.jpg[/IMG]
      12-11-2008, 04:02 PM   #7
modbargains
171
Warranty is 1 YEAR :biggrin: !!!
      12-12-2008, 05:29 PM   #8
modbargains
171
PMs replied!
      12-15-2008, 07:07 PM   #9
modbargains
171
      12-17-2008, 04:02 PM   #10
modbargains
171
PM for any questions that you guys might have!
      12-26-2008, 07:00 PM   #11
modbargains
171
5% off CROSS products everyone!
1addicts
