11-17-2008, 05:52 AM | #1 |
Rep 2,042
How to remove trunk liner to access 3rd brake light?
Do those plastic pop rivets come off by levering with a screwdriver or do you need a special tool? I tried with a screwdriver and an old rag but was a bit afraid to use too much strength just in case i broke something.
01-01-2015, 04:37 PM | #5 |
Rep 566
I had a similar question to OP and didn't want to create a duplicate thread so I'm brining this one back from the dead.
Does anyone know where I can find the mentioned tool to remove the rivets? Does it have a name I can reference?
CURRENT: 2013 TSM 335i 6AT | Stock!!...for now | SOLD: 2010 CR 135i 6MT | 351 WHP 387 WTQ | Dinan Stage 2 | Dinan Intercooler | BMS DCI | Berk Street Axle Back | N55 Midpipe | BMWP Y-Pipe | Bilstein HD Dampers | BMWP Springs | Whiteline RSFB Inserts | 225/255 RE71R | CDV Delete | CF Diffuser | |
01-01-2015, 05:44 PM | #6 | |
Rep 1,293
http://t.harborfreight.com/5-piece-a....google.com%2F If/when you need to remove other push rivets and tabs around the dash, doors, front bumper, etc., the nylon pry bars won't mar the finish of the part being removed. |
01-01-2015, 06:05 PM | #7 |
European Editor
10616
Rep 22,992
This might help you out...
DIY third LED brake light replacement... http://www.1addicts.com/forums/showthread.php?t=845005
01-01-2015, 09:56 PM | #8 | ||
Rep 566
