      12-04-2008, 11:35 PM   #1
j8smith
Drives: 128i coupe
DIY: Install the dash top storage bin
I decided I wanted to install the dash top storage compartment that’s available outside of North America. A quick check of real-oem showed there is a retrofit kit available
Step 1
I ordered the storage compartment retrofit kit Part # 51450428424 from Tischer BMW, and it took 3 weeks to come from Germany and cost $85. It comes with a cutting template, fasteners, a wiring harness and the storage bin. It didn't come with the install instructions, but Jason at Tischer emailed them to me. These instructions are basically useless as most of the diagrams are missing or incorrect.
Step 2
Cut out and align the cutting template and stick it to the dash. I used a marker to mark where to cut, than removed the template.
Step 3
Now it’s time to cut a big hole in your dash. The install instructions say to use a vibratory saw for this but I don’t now where you would find one of these. I ended up using a rotary tool with a flex shaft and a rotozip bit. It mostly just melted through the plastic, but it worked fairly well.
Step 4
Remove the center vent using a plastic trim tool at 4 points, where the indentations are on the dash panel.
Step 5
Install the supplied metal clips in the mounting points in the dash
Step 6
Connect the wire on the storage bin to the unused connector clipped to the steel tube in the dash. This is for the light in the storage compartment
The Kit also comes with a wiring harness that is meant to tie into the glovebox light wiring. DO NOT USE THIS. The glove box light always has power so if you use this, the storage compartment light will always been on. The unused plug already in the dash is tied to the interior lights and is only powered when the headlights are on.
Step 7
Remove the rubber matt from inside the storage compartment. Then install the compartment into the dash.
Step 8
Install the 4 torx screws that secure the storage compartment to the dash
Step 9
Reinstall the rubber matt, then reinstall the center vent
Step 10
Vacuum up all the plastic shavings that are now all over your interior.
And that’s it, you are done
[SIGPIC][/SIGPIC]
      12-04-2008, 11:42 PM   #2
Lester
Drives:
What do you plan to keep in there?
      12-04-2008, 11:49 PM   #3
j8smith
Drives: 128i coupe
I was thinking about using it to mount a scanguage or a portable GPS like in this thread:
http://www.1addicts.com/forums/showthread.php?t=19233
Jay
[SIGPIC][/SIGPIC]
      12-05-2008, 12:59 AM   #4
1Ronnie
Ronnie
1Ronnie's Avatar
Drives: '08 Sedona 128i
Holy Crap !! I can not see myself taking any electrically powered sawing device to the center of my dashboard ... you're a very brave man, well done !!
"Lucy"
128i / Sedona Red / Coral Red / Premium Package / Premium Sound
      12-05-2008, 07:46 AM   #5
BlackjackMulligan
Most interesting Roadster
Drives: '01 Z3.0 Roady;'10 C300 Sport
Nice job dude, you got big cajones to cut into your dashboard like that! I had a box like that on my X3, kept my sunglasses in there. You'll find a use for it I'm sure!
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh
      12-05-2008, 07:47 AM   #6
JTdrivin1
1 Love
Drives: 2011 135i 6MT
Damn... that's a huge hole in the dash, and then a large open cover to just have a GPS up there. I put my Garmin in the ash tray above the shifter. It fits there perfectly and doesn't move when you wrap the cord just so.
But hey, whatever floats your boat...
      12-05-2008, 08:39 AM   #7
jtsherri
jtsherri's Avatar
Drives: TBD
2008 135i  [10.00]
Alright, I cut the hole in my dash, but now I have this extra flippy thing with LCD sitting on my garage floor... Do I just throw it away?
J/K - nice work. Very clean install!
      12-05-2008, 09:09 AM   #8
1Ronnie
Ronnie
1Ronnie's Avatar
With some glue, cable ties, and effort, you'll be able to mount the LCD thingy in the storage bin !!
"Lucy"
      12-06-2008, 05:26 AM   #9
135iUSN
19 X5 1998 M Roadster
135iUSN's Avatar
Drives: 135i Alpine White / Terra
1998 BMW M Roadster  [0.00]
2009 135i  [0.00]
crazy...nice chunk of value just taken...from the car..
better yet, a set of cup holders would have added more value..
'09 135i Dinan In BMW heaven 09.28.2022 - Stage 2/Alpine White w/Terracotta /High Gloss Black Trim/ZCW/ZPP/ZSP w/313's /CA/PDC/Steptronic/
      12-06-2008, 05:55 AM   #10
mrgoochio
135i Coupe Owner!
Drives: 2008 BMW 135i Coupe
Why do you say that? It's a genuine BMW part.. I wouldn't consider adding performance exhaust or CF diffuser etc. as mods that lower resale value compared to 3rd party aftermarket.
2008 BMW 135i Coupe
  • Jet Black
  • Sport Pkg.
  • P1 Lemon Boston Leather
  • High Gloss Black Trim
  • Comfort Access System
      12-06-2008, 09:55 AM   #11
BlackjackMulligan
uh, no......he didn't affect the value by adding an OEM piece to the car
- Joe Walsh
      03-15-2009, 02:38 PM   #12
j8smith
Drives: 128i coupe
template
A couple of people have asked for the cutting template that came with the retrofit kit. so here it is.
[SIGPIC][/SIGPIC]
      03-15-2009, 03:13 PM   #13
bozola
Unloved BMW Addict
bozola's Avatar
Drives: Z3 Coupe, 3 318Ti
1999 Z3 Coupe  [10.00]
1998 318Ti  [0.00]
1998 318Ti  [10.00]
2008 128i  [9.00]
Very nice. and Very Tempting!
      03-16-2009, 01:31 PM   #14
jmr_70
jmr_70's Avatar
Philippines
Drives: 135i, 325i
Good job man....very clean looking. I think I want one.
      03-16-2009, 02:02 PM   #15
jeremyc74
Drives: '08 135i Montego/Terra
X2!
End result looks great!
      04-11-2009, 10:13 PM   #16
M3Armand
M3Armand's Avatar
Drives:
Damn nice job... I think I will be doing this as well...
2004 Porsche 911 C4S, Seal Grey / Black, X51, Sport Exhaust, Carbon Fiber
2006 Porsche Boxster S, Guards Red / Beige
2001 Audi A4 1.8T Quattro, Laser Red / Black, APR Stage 2, H&R Coil Overs, Window Tints, BBS Wheels, Combination Pillar Boost Gauge/Airbag, Xenon Headlights
2008 BMW X5 4.8i, Black Sapphire / Saddle Brown
      04-13-2009, 03:11 PM   #17
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
MMMM.. really? Thats what i have been looking for..
I have a secret plan now..
      04-15-2009, 12:44 PM   #18
john08135i
john08135i's Avatar
Can you post some pics with a ruler for measuring the actual cubby size of depth and width PLEASE.. good sir..
      04-15-2009, 01:42 PM   #19
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
Hmmm....very intriguing...I might do this one day...nice work man!
Originally Posted by ptack View Post
SGM was God's color and has been recalled to heaven.
      04-16-2009, 04:35 PM   #20
takrdown
Other car was a submarine
takrdown's Avatar
94
Drives: i4M50 (waiting), 2013 R56 JCW
Subscribed for when I finally get my baby over here...nice work!
      08-26-2009, 09:05 PM   #21
Jeespinozar
135i fan
Drives: 2008 135i 6sp, 2013 135i DCT
I certainly need something like this. Good job and very clean finish. Congratulations
Jorge
      08-26-2009, 11:29 PM   #22
CAMike
Drives: 2008 135i
I'm in Europe and have asked my dealer about doing this. They say it can't be done but now I have a part number and can see about getting it done. Great job!! Thanks!!
Mike
1addicts
