      01-16-2009, 12:30 AM   #1
WhiteOut
Drives:
Seat removal
I'm considering buying bucket/race seats for track but want to use my stock seats for the street. How difficult / time consuming would it be to interchange the front driver seat? I should note my seats are manual (non-powered)
      01-17-2009, 04:43 PM   #2
Add1ct
Add1ct's Avatar
61
Drives: 135i, 335i
do you have sport seats? if so are they leather? if so do you want to swap for leatherette? that said- I had non-sport leatherette and picked up the two front leatherette sport seats on here and installed them myself- not at all difficult, 4 bolts each and then the wiring which just unclips, took me about 1.5 hours tops maybe, you need a torx T55 or T50 I can't remember which though, but not hard
E82 N54 6MT 6FL 668 KASW turned in
E92 Crimson/Cream N54 6MT, ZSP, ZPP, ZCW, Nav, Sat radio, HD Radio, Logic7, PDC, Active Steering, Active Cruise, 6FL, CA
      01-18-2009, 10:56 PM   #3
WhiteOut
Drives:
I have heated, sport, leatherette. Thnx for the info
      10-17-2011, 11:30 AM   #4
G2JAY
United Kingdom
Drives: 120d Coupe
I have just found your comment on the Iseries coupe seat exchange. I want to remove the sandard seats and replace with the half leather sport seats, having already obtained an as new pair. I am nervous about unpluging the existing seats; will this not cause an error with the airbag system? Even if I remove the nedative connection at the battery, this in itself is likely to generat an error message is it not?
      10-17-2011, 12:20 PM   #5
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
You will also have some error codes with Airbag malfunction which is not very easy to solve
      10-17-2011, 03:12 PM   #6
JimD
JimD's Avatar
369
Drives: 128i convertible
You can't just clear the error codes? I haven't tried this on my BMW - haven't gotten any codes yet - but on my other cars, this is very easy with a OBDII reader.
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      10-18-2011, 12:38 AM   #7
HondaGoneRogue
They like my Swag...
HondaGoneRogue's Avatar
433
Drives: 15 GSM 435i GC
Nope, you can't clear them like that. Also, removing the front seat disables the passenger airbag as well.
2015 435i Gran Coupe - Current
2008 AW 135i - Sold
      10-18-2011, 02:05 AM   #8
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
It is possible to disable airbags through coding but do you want that?
Also swapping seats every week or so.... better to decide which ones you want. If you want racing seats get them installed and disable seat airbags to not get error codes
      10-18-2011, 02:00 PM   #9
Groundpilot
Groundpilot's Avatar
Drives: 135I DCT , e92 M3 DCT, Audi A6
Here is what you need:OC3-seat occupancy sensor emulation module. Macht Scnell makes them. EAS sells them for about $300 if i remember correctly.
1addicts
