01-29-2009, 12:28 AM | #1 |
Rep 409
Is parallel parking with M-DCT difficult?
As opposed to a manual tranny?
I just wonder, can´t find any previous posts on it. Thanks! |
01-29-2009, 01:08 AM | #4 |
Rep 33
No issues here. Just like a manual it shifts from reverse to drive while the car is still rolling backwards, assuming you want to use the DCT to end your rearward momentum, instead of your breaks.
01-29-2009, 01:33 AM | #5 |
Rep 2,426
“For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.”
- John 3:16 |
01-29-2009, 06:27 AM | #6 |
Rep 409
Thanks for the info! And to Big Windy; it sure must be different? As I now understand it´s probably not more difficult as opposed to a manual, but it sure must be different. I´m not saying anything negative towards any of the tranny options (hell no...), I just wanted to get some insight I drive a manual non-M and parallel park a lot. Probably too much.
01-29-2009, 07:40 AM | #8 |
Rep 5,124
01-29-2009, 08:17 AM | #9 |
Rep 409
But when parallel parking there´s often a lot of back and forth and so on so I just wondered if it was easier to control the maneuver with a stick, but probably not then.
01-29-2009, 08:35 AM | #10 |
Rep 589
Still dont understand what hes talking about.. whats the difference??
hi
01-29-2009, 08:37 AM | #11 |
Rep 5,124
Ok, so you're talking about having to go back and forth between forward and reverse gears. I guess that if you do it right you'd really only need to go back into the spot, and then forward to get lined up. Unless the spots are really difficult to get into...I would assume that DCT would be similar to any regular AUTO in this regard, right?
01-29-2009, 09:16 AM | #12 | |
Rep 409
01-29-2009, 09:20 AM | #13 |
Rep 5,124
I've never heard this issue come up on the forum before, so I'm sure you're safe. With all the DCT guys on here, I'm sure someone would have mentioned it were it an actual issue.
01-29-2009, 09:24 AM | #14 |
Moderator
7525
Rep 19,368
Parallel parking is easy. It is perpendicular parking that is more difficult. You have to put the car in the special "Z" gear that's only available in S6.
And "skew" parking? Forget it. How the heck can you get the car to float or burrow into the ground? I sure haven't found a way yet. |
02-01-2009, 07:14 PM | #15 |
Rep 183
Changing between forward and reverse gears is as easy as in any auto and with no jerk between the gears. However moving very very slowly, eg to get as close as possible to the garage wall, is more difficult than in either a normal auto of MT. You use a touch of gas to start it moving and then control the speed with the brake. However if you brake too much it stops and you have to use gas again to restart. Also, it is not as smooth doing this as a normal auto.
Unless you have to move extremely slowly in order to get very close to something you would never notice this problem. I have not seen it mentioned elsewhere. |
02-01-2009, 07:58 PM | #16 |
Rep 136
Somebody needs to practice parallel parking.
02-01-2009, 08:37 PM | #17 |
O! So Sour!!
552
Rep 15,615
Drives: Fast 240z / Slow M3
can you parallel park with a automatic? If yes, then no to your question. But if you cant parallel park for shit then it doesnt matter which type of tranny your driving.
02-01-2009, 09:52 PM | #18 | |
Rep 91
Yeah, parallel parking (or any type of slow, close-quarters movement) in the E46 SMG is difficult. It's because the SMG is almost like an on/off switch, and you can't always predict when it's going to kick in. So if you're trying to inch forward (or backward), you have to keep increasing pressure on the gas pedal until 1st gear engages, and then quickly get on the brake to prevent it from rolling too fast. I agree that it's more difficult than both an auto and M/T. |
02-02-2009, 06:50 AM | #19 |
Rep 1,171
When I realy want to be precise "by the inch" I pull the handbrake a couple of notches. I found that this helps a lot when you want to move really slow and for very small distances, but its not to be made a habit of course. I very rarely do this - just did it a coupel of times over the past 7 months of ownership.
02-02-2009, 01:48 PM | #20 |
Rep 409
02-02-2009, 02:06 PM | #21 |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
If you have to shift from reverse to 1st more than once, then you aren't doing it right. If you parallel park a lot, then you should have it down by now.
In any case, I can park in my garage within an inch of where I want to, no different than MT or auto, no problem. Creep mode works just fine. |
02-02-2009, 02:13 PM | #22 | |
Rep 409
