BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      02-07-2009, 04:38 PM   #1
03SG///M3
Drives: 328
AC Schnitzer Racing Supension
Does anyone have the ACS racing suspension? I was looking at this on CEC's website and it looks interesting.
      02-07-2009, 09:37 PM   #2
GregW / Oregon
Commander-In-Chief
2122
ACS springs have been reported on: http://www.m3post.com/forums/showthread.php?t=202004. Are you talking springs + shocks?
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      02-07-2009, 09:46 PM   #3
MentholGuy
MentholGuy's Avatar
Drives: 11 E90 M3
Racing suspension kit is a whole new suspenion kit, not just springs.
I have ACS springs now but I'll upgrade it to racing suspension kit soon.
Check this post, Frank@CEC has racing suspension kit on his M3.
http://www.m3post.com/forums/showpos...2&postcount=18
      02-07-2009, 11:50 PM   #4
FrankieP
FrankieP's Avatar
Drives: E92 M3 AW/BLK
Here are some shots of the system while I was installing...
The suspension his height adjustable as well as 20 position dampening adjustable. The stiffness can be easily adjusted by turning the front wheels and clicking the red anodized knob clockwise. On the rear you can adjust the knob by reaching behind the wheel from the side of the rear bumper. (2 min total) For those with EDC, ACS offers a control module which will eliminate the function and not display any EDC faults. The range of adjustability this suspension offers is incredible. You can have a comfortable daily driver, and a couple clicks later, you're track ready.
      02-08-2009, 04:15 AM   #5
///M PWR 00
///M PWR 00's Avatar
91
Drives: Porsche
I am very interested in these... How much? And in the photo of the white M3 is that the lowest these go?
      02-08-2009, 06:45 AM   #6
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
And how much is this...? lol
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      02-08-2009, 01:12 PM   #7
03SG///M3
Drives: 328
Yes this is the suspension system I was referring to. It looks very nice. I would be primarily interested in the track performance of this kit. Does acs offer camber plates?
      02-08-2009, 11:24 PM   #8
FrankieP
FrankieP's Avatar
Pricing can be found here:
http://www.cecwheels.com/tunerproduc...3/3SeriesE92M3
There are plenty of sponsors on this board that are authorized dealers, so feel free to use your favorite.
The suspension as seen in the pics is set to -5 mm lower than ACS suggested specs. It will go a bit lower in the front, and about .75 inches lower in the rear. The control module for those with EDC is not included in the price list, but is currently available. This module lists for $795. ACS has not released camber plates for the E9X M3 yet.
      02-08-2009, 11:52 PM   #9
///M PWR 00
91
Drives: Porsche
So is this a coilover system or what? 795 sounds cheap!
      02-08-2009, 11:55 PM   #10
FrankieP
FrankieP's Avatar
$795 is for the module that eliminates the EDC function for those who have EDC and would like to run this suspension.
      02-11-2009, 01:52 PM   #11
03SG///M3
Drives: 328
This is a very nice suspension. Do you have any track time with this suspension? Track performance is my primary purpose in buying a coilover suspension.
      02-11-2009, 04:50 PM   #12
FrankieP
FrankieP's Avatar
This suspension was developed and tested at the Nurburgring. It shares no components with the standard E92/93 version. It was engineered solely for the E9X M3.
The following info was taken from ACS Germany's official press release:
This suspension consists of "upside-Down" dampers and coil springs for the front axle, and dampers and springs with multipiece aluminum height adjustment for the rear. This not only makes steering behavior more precise, but significantly improves traction. The limit zone is moved perceptibly upwards, as reflected by lap times. Two adjustable parameters characterize the racing suspension, so bound and rebound dampening are variably adjustable via a knob. This means the damper characteristics can be easily and quickly set to the dampening force required. This innovation in "upside-down" design is constructed as a monotube system and is characterized by many advantages:
* fast response
* wide adjustment range
* low weight
* simple handling
In this "upside-down" construction, the piston rod doesn't point up towards the fixing point, but down towards the wheel mounting. The advantages: The heavier components are attached to the bodywork, the lighter ones to the suspension. So the unsprung mass id reduced. The system even absorbs high transverse forces very efficiently, is extremely robust and ensures a long useful life. This system has already proven successful in motor racing.
They do not post any lap times, but I will ask them and update the thread.
      02-12-2009, 04:45 PM   #13
03SG///M3
Drives: 328
* fast response
* low weight
* simple handling
Thanks for the additional information. I would be curious to see if they have lap times. How long would it take to get this suspension? Does ACS offer sway bars too?
      02-14-2009, 08:29 PM   #14
FrankieP
FrankieP's Avatar
The suspension is in stock now in the U.S. Sway bars are not yet offered for the E9X M3.
      01-06-2010, 12:16 AM   #15
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Anyone know the spring rates on this kit?
      01-06-2010, 10:26 AM   #16
Eugene-TAIWAN
Eugene-TAIWAN's Avatar
Taiwan
249
Drives: E92 M3 Coupe
my friend has this set up in Taiwan.
He thinks is OK . don't know about the spring rate but the ride is comfortable. and there are like 20 settings or something along those lines. But I think these coilovers are expensive. Maybe its cheaper in the states I don't know.
Past: Gintani stage3 M3, Cayman GTS
present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW
      01-06-2010, 12:53 PM   #17
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Can you elaborate a little bit more on why it is "OK". For example, does it feel stiff enough for the track?
      05-14-2010, 12:46 PM   #18
STALKER
Drives: 997.2 GT3, Golf R
Anymore feedback?
      05-14-2010, 02:18 PM   #19
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
These are single-adjustable?
      05-14-2010, 02:57 PM   #20
STALKER
From that I have read so far, they seem to be SA shocks and monotube.
      06-22-2010, 04:58 PM   #21
STALKER
Anyone running these???
Any real feedback?
m3post
