04-27-2009, 06:00 PM | #4 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
i think the fuse is for the entire headlight
when i checked the fuses there is only one fuse per side whats the problem with the DRLs? |
04-27-2009, 06:05 PM | #6 |
Rep 6,845
is everything else working?
did you try all 3 positions on the headlight switch? auto and the 2 manual settings? do the turn signals work with the drl mode? headlight? corner lighting? |
04-27-2009, 06:05 PM | #7 |
Rep 6,845
i would also use a mutlimeter to measure the voltage going to the DRLs
should be around 11v when on and 3v when the headlights are on |
04-27-2009, 06:11 PM | #9 |
Rep 6,845
that's weird
are you sure the bulbs are ok? i would guess its not a fuse issue at the fuse box behind the glove box is there another fuse box at the driver kick panel ? i know the lighting wires lead there don't have the manual with me right now |
11-07-2009, 04:56 PM | #11 |
Rep 396
My drls don't work anymore either.... I shut them off for a second last week to see what lights shut off...using the Idrive I then turned them back on and they show the check mark whenever I go into the settings menu but they don't turn on when its sunny outside... So weird
Anyone have any ideas how to get them back on again....everything else with the lights works great and at night of course they are on |
11-07-2009, 11:53 PM | #13 |
Rep 5,012
Are you guys talking about stock or aftermarket DRLs? I'm betting the latter . First thing to do is put stock ones back and see if they work. If stock, I'd check the bulbs and voltage on the sockers. Can't imagine DRLs not having their own fuse or relay; maybe a tech can shed some light on this. Good luck.
11-08-2009, 10:27 AM | #14 |
Rep 396
Stock drls no control message.... I took them off in idrive then I put back on and now they show a chec box but don't come on or show on the dash unless its dark out... I have concenience package and I'm guessing it has something to do with that or the key.... Very confused
