04-29-2009, 11:40 AM | #1 |
Rep 3,039
KW V3 Coilovers
I know the height is fully adjustable, so I'm wondering compared to stock how low will the coilovers make the car at its highest setting?
Can I retain stock ride height during the winter, then drop in down for the summer? |
04-29-2009, 12:04 PM | #2 |
Rep 1,164
You have a lot of adjustment, and should be able to make it higher than stock if you wish.
-Andy
2008 M3 Sedan- Alpine White
04-29-2009, 12:26 PM | #3 |
Rep 1,753
Maybe the V3 are different from the V2 in height adjustability, but when I put the V2's on my 335I, even at max height settings, it was lower than stock.
18? Camaro 2SS 1LE
16' M3 MG Ext. /SO Int. (DCT, Ohlin R/T, 19" wheels) 15' Audi S4 13' Audi TTRS (APR stage 1, MSS springs) 09' C6 Z06 08' M3 Interlagos Blue: 6sp, Tech. |
04-29-2009, 02:51 PM | #4 |
Rep 3,039
Ok I just found this on bimmer performance stores website.
"KW suspensions announces their Variant 3 stainless steel constructed coil-over for the 2008 BMW M3. The KW coilover suspension for the 2008 BMW M3 enables the owner to lower their vehicle 10-40mm on the front axle and 5-35mm on the rear axle and retains enough travel to handle maximum load and dynamic loads during driving." So at its highest setting it will only be .39" lower in front and .19" lower in the rear, and at its lowest it drops the front 1.57" and the rear 1.37" and I guess anywhere in between. Can someone confirm these specs? |
04-30-2009, 12:40 PM | #5 |
Rep 860
When my guy installed my V3s, I asked him to maintain stock height, for starters. When I picked the car up, the front end was WAY higher than stock (confirmed by measuring another stock M3).
So, yes, it is possible to have at least the front end higher than stock height. Only problem with adjusting it repeatedly, is that it is recommended to have an alignment done with each adjustment - not the most convenient, but recommended.
"Anima sana in corpore sano"
04-30-2009, 01:25 PM | #6 | |
Rep 3,160
06-19-2009, 10:07 PM | #7 | |
Rep 175
2022 M240i | Brooklyn Gray | Red Leather | Black 791M rim| Black trim | HK | Premium | M Lum
06-20-2009, 01:18 AM | #8 | |
Rep 860
I am definitely no expert, however. Just my thoughts - I would re-align, but I am a little OCD that way,
06-20-2009, 06:42 AM | #9 |
yodog
197
Rep 5,025
Any adjustment to suspension height via springs/shocks needs an alignment for full potential handling. Changes in height via new wheels/tires, an alignment is not needed.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
06-24-2009, 06:53 PM | #10 |
BimmerPost Supporting Vendor
257
Rep 4,048
Here's a few pictures to help you out what kind of settings you can go with:
What we opted for when we were on stock 18"s: What she looks like now: More information can be found here: http://www.m3post.com/forums/showthread.php?t=150287 |
12-09-2009, 11:07 PM | #11 |
Flying First Class
30
Rep 582
I know that kw gives you their specs for optimum handling. My question is if you go beyond those specs (ie. go lower than what they spec says is optimal) and something goes wrong like a shock blows, will kws warranty cover the damage?
12-11-2009, 03:11 PM | #12 |
yodog
197
Rep 5,025
I believe if you jus get the standard V3's it's a lifetime warranty but you do have to pay for the labor to take out the shock.
12-11-2009, 04:03 PM | #13 |
Bla!
82
Rep 909
I can't give you a definitive answer, but logically, yes. Their system is designed to work "flawlessly" together, so logically, if something goes wrong, they should cover it.
