05-17-2009, 04:42 PM | #1 |
Rep 528
307 km/h with limiter!
My car has the M Drivers Pack where the limiter is raised to 280 km/h. My two previous tops speed runs both resulted in 286 km/h and the car wouldn't go past that. The other day I was able to pull 307 km/h and drove over 300 for about two minutes before running out of road. What do you think is the reason for these differences?
p.s. road was pretty similar in all runs |
05-18-2009, 12:23 PM | #3 |
Rep 5,483
and where did you do those speeds?
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
05-18-2009, 12:53 PM | #4 |
Rep 2,008
Likely Europe. I don't know where else you could do 180MPH for several minutes.
(Waitlist): #1 M2CSL
(Current): 2016 F15 X5 3.5xdrive - 2010 997.2 C4S Coupe (Past): 2016 F30 340xi M-Sport -2013 535i xdrive 2008 E92 M3 - 2006 E90 325i 2002 E46 325xi - 1991 E30 325i |
05-19-2009, 12:58 AM | #5 |
Rep 528
I would think that the speedo optimism is the 286-280 difference of 6 km/h that I have got on two occasions (286 indicated, supposedly 280 real). My car would stop to accelerate at precisely that speed twice, it was clearly a speed governor. Now the last time was different it didn't bounce off any limiter it just reached its top speed and the speed would change up and down between 307, 306 and 305.
p.s. could it be that I have done a heavy track day and passed the 10 000km mark before the last attempt? All runs were done on highway in Eastern Europe |
05-19-2009, 03:31 AM | #6 |
Rep 360
Drives: M3/E90/SSII/19s
I am afraid your Speedo is a bit off... I have no limiter and hit 300kmh on the speedo while external GPS showed 285kmh (+15kmh, +5%), you seem to have a +27kmh (+9%)...
btw, I am sure it can do 300kmh GPS without the limiter (= 320-330 on the speedo), eventhough I never had enough 'free' road... (on the A31 North).
2008 M3 E90/SSII/Black/6MT/19s/chip=456PS |
05-19-2009, 04:06 AM | #8 | |
Rep 528
05-19-2009, 04:21 AM | #9 |
Rep 360
Understood. However, I think the 286kmh is not the 280kmh real, but the 305-307kmh is the real 280kmh in your case. As you say the car would not go passed 307 on the speedo, it means you have a limiter. The car would easily go 320kmh on the Speedo without a limiter. As I had 300 Speedo, it still had lots of power/acceleration, but other cars on the road caused me to slow down.
Normally I would expect +5-7% on the Speedo. So 280 limiter would get you to 295-300kmh on the speedo. If you get 307kmh on the Speedo with a 280 limiter, that is +9%. This is not really bad (as I have seen +10% in previous cars as well). You could try to fix a Garmin or Tomtom and see what gives you that. Those machines have highest speed memory, so no need to focus on GPS while doing Boeing-speeds... Good luck!
05-19-2009, 04:40 AM | #10 |
Rep 86
have you changed your wheels / tyres ?
With the 19' : limiter = 275 (i do not have the 280 limiter option) with the winter kit from BMW, 18', limiter = 285. difference is due to a small difference in the size of the tyres. BTW, if we take the same difference between the speed read on the tacho, and the top speed as per BMW me With 19': BMW 250 / Tacho 275 You: BMW 280 / Tacho 307 same difference. You did not reach the limiter when your top speed was only 280+ |
05-19-2009, 10:21 AM | #11 |
Rep 528
Tyres and wheels are stock and I clearly hit the limiter on my two previous attemtpts at 286, however, it didnt kick in at my 307 effort, the car just didnt want to go any faster.
05-20-2009, 02:36 AM | #12 | |
Rep 360
And try the GPS. Hopefully it does hit 280+ on GPS. Good luck and have a nice flight!
05-20-2009, 11:31 AM | #13 |
Rep 528
I run the stock 19s with ps2 and 100 octane RON. I have a Tomtom, will give it a shot when I get a chance again. Is the Tomtom accurate when it comes to speed?
05-20-2009, 03:22 PM | #14 |
Rep 360
TomTom will do. Let us know the outcome!
05-20-2009, 03:38 PM | #15 | |
Rep 8,026
That is what I think is happening here. The only thing I am less sure of is if 5% continues as speed increases, one would expect that at speeds of 80km/h the speedo would and should show 88km/h but I honestly would have though the difference would peak at 15km/h and hold that figure beyond the 150km/h point. |
