05-18-2009, 06:41 PM | #1 |
Rep 3,110
Metallic Knocking Noise at Rear??
hi,
yesteday night my car starting making a pretty loud metallic knocking noise at low speeds, not at idle, from about 2kmh to 20 or so...it kinda sounds like you are hitting an empty coke can...loud metallic knocking and "tinkling." it seems to be coming from the rear, i think drivers side. i went for a hard drive yesterday all day, but i had no issues? |
05-18-2009, 06:47 PM | #2 | |
Rep 5,393
Drives: 08 JB E92 M3
A quick search will bring you to all those discussion threads in a beat! |
05-18-2009, 06:52 PM | #3 | |
Rep 3,110
the car kinda always had a light mechanical tick sometimes, but nothing like this it doesnt happen when turning particularly if at all. when i start or roll out of the drive-way or a stop sign, its knocking around.... |
05-18-2009, 06:58 PM | #4 | |
Rep 8,050
Drives: E92 M3
08 E92 M3/Melbourne Red/6MT/Exec Pack/MDrive/EDC/PDC/19" 220M
Mods: VRS Front Lip, HID Angels, KW V3, Stoptech BBK, SS lines, 18" TE37SL, Bastuck Exhaust, MS Air Filter, OEM Aluminum Padels, LED Interior Light 07 E92 328i/Jet Black/Cream Beige Leather/Premium/Step/Heated Seats...check garage! |
05-18-2009, 07:00 PM | #5 | |
Rep 8,050
Drives: E92 M3
So this happened after our drive? Best bet is take it to the dealer tomorrow morning if you are not busy! GL bro
05-18-2009, 07:02 PM | #6 |
Rep 1,159
05-18-2009, 07:37 PM | #7 |
Rep 3,110
im already going to the dlr tomorrow morning around 11am for some work so i will add this, its just confused as to what it is and driving it and all that...
thks |
05-18-2009, 08:05 PM | #8 | |
Rep 136
05-18-2009, 11:23 PM | #10 |
Rep 3,110
05-19-2009, 01:37 AM | #11 |
Rep 5,393
05-19-2009, 03:12 PM | #13 | |
Rep 83
05-20-2009, 10:02 AM | #14 | |
Rep 3,110
05-20-2009, 10:55 AM | #15 | |
Rep 83
05-20-2009, 07:40 PM | #16 |
Rep 1,636
I had the noise once ...there was a thread for it
http://www.m3post.com/forums/showthr...ird+noise+back |
05-20-2009, 08:11 PM | #17 | |
Rep 3,110
05-21-2009, 08:16 AM | #18 |
Rep 1,636
I think it was a rock got stuck between the rotor and the shield. I remember driving on a stripped paved road the night before that happened to me
05-21-2009, 11:49 AM | #19 |
Rep 1,469
It has happened to me 4 separate times. It is definitely a small rock caught between the brake caliper and the black aluminum shield behind it. It will go away. Also, this is different from the lower thumping rotational noise the differential makes from the back right wheel on slow right turns. I had that too. Dealer replaced differential fluid and all's well...
05-21-2009, 01:56 PM | #20 |
Rep 86
Mine did this for a day and a half day. Sounded very metallic like something was stuck in the spokes of a bicycle. I even got under the back of the car(sound was coming from the rear) with a flash light to see if a wire coat hanger or some kind of road debri was stuck up under there or something. Didn't see anything. Didn't even think to check the brakes. Never thought a rock would be stuck in there. But it was exactly how you guys are describing. Forward or reverse, rolling slow, clutch in or out, in gear out of gear. PING! PING PA-PING! Then the next day.....nothing. I even made an appointment at the dealer, but canceled because it went away. So you think it was really a rock in the brakes?
05-21-2009, 07:15 PM | #21 |
Rep 243
Had same problem. At slow speed (5 mph) could here a loud metalic pinging sound coming from the left rear wheel. As the wheel rpms sped up, the sound would disappear. I guess the rock would get pinned by the centrifugal force of the rotating wheel. I was unable to see any foreign object and had planned to remove the wheel. Before I got around to this, the sound disappeared.
05-21-2009, 07:36 PM | #22 |
Rep 6,007
yep, this has be discussed in a number of threads. It's happened to me numerous times and then goes away for a long time. I have a pebble driveway so I'm sure that causes the stone to get there most of the time.
