06-12-2009, 11:19 AM | #1 |
Rep 536
LeatherZ - Complete E8x Gauge Kit!
The LeatherZ E8x Complete Gauge Kit is now Available!!!
You pick the gauges you want! On our other gauge kits, we always offered one or two different kit options when it came to the gauges. For the E8x 1 Series, I decided to try something a bit different. I decided this time, that I would let you pick the gauges you wanted to run in your car. How does this work? When you order your gauge kit, you will be given 3 choices for your gauges. When you select a gauge, the online shopping cart will add that gauge and any necessary senders, connectors, wiring, etc. to the kit. Because the cost of the senders will vary depending on the gauge, the final price of the kit will depend on what gauges you select. Our complete kit includes everything you need to install a 3 gauges into your 1 Series. The kit includes the following items:
LeatherZ Oil Distribution Block with Oil Pressure Sender: Last edited by AndyM; 06-12-2009 at 03:08 PM.. |
06-12-2009, 11:29 AM | #2 |
Most interesting Roadster
70
Rep 2,224
Drives: '01 Z3.0 Roady;'10 C300 Sport
very cool, reminds me of the gauges on my old VW GLI
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh |
06-12-2009, 03:10 PM | #3 |
Rep 536
Someone asked for a picture of the kit in action. Not sure what he meant, but here goes. I am not sure how to get a picture with the boost moving, not sure if I want to try with the car under WOT.
06-12-2009, 07:55 PM | #4 |
Rep 718
Looking good! How hard is it to see while you're driving? Would you be able to see your boost pressure while under WOT without losing too much of your field of vision?
06-12-2009, 09:05 PM | #6 |
Rep 395
Wouldn't recommend a boost gauge down there
LeMans 135i ///M-sport 6MT
06-13-2009, 12:47 AM | #11 |
Rep 204
not to complain or anything, but i hate having to try to wire stuff in the dash myself, at least six hours or more? wow. need to take this project to the shop then.
06-13-2009, 08:52 AM | #12 | |
Rep 536
I will install the kit for free (no kidding) in Cincinnati. Last edited by AndyM; 06-18-2009 at 10:28 AM.. |
06-13-2009, 09:04 AM | #13 |
Unindicted co-conspirator
66
Rep 1,734
Drives: to work, mostly.
Just curious - do you sell a kit to relocate the cig lighter/power point for those who wish to retain it with this kit?
06-15-2009, 05:28 PM | #15 |
BMWCCA member
Rep 87
Andy,
This package is what I have been waiting for! Is this plug and play or is there splicing to do (worried about warranty issues)? Does the boost gauge go to a transducer and then into the cabin or does the tubing come into the cabin? And, what panel is represented by the 5th and 6th pictures in your OP? |
06-15-2009, 06:16 PM | #16 | |
Rep 536
I use a mechanical gauge so the tubing is running into the cabin. The boost gauge picks up at the vacuum line right at the diverters. BMW has a T-fitting there so adding a 2nd T is easy and you can go back to stock. There is some tapping into existing wiring, but if you are careful, it is easy to hide. Feel free to give me a call to discuss the installation in more detail. |
06-15-2009, 09:04 PM | #17 |
BMWCCA member
Rep 87
Another thought: any option for 2 gauges and the power port/cig lighter on the panel (hint-this maybe a seller as well as most probably don't need/want 3 gauges and also don't want to give up their power port). Food for thought...
But, I will order, but would like to either (1) know your thoughts on the above option (2) know when you are finished with your port diverter option you are already working on. I want to have a power port in the area to charge "stuff". Thanks |
06-15-2009, 09:20 PM | #18 | |
Rep 536
06-17-2009, 02:09 PM | #19 |
Rep 536
I have the LeatherZ E8x Power Relocation Kit ready for pre-order.
If you are a tech junkie who relies on the car’s power socket to keep your electrics charged, losing the Power Socket for our E8x Gauge Kit can make it a tough sell. We feel your pain, that is why we are offering this simple, plug-and-play Power Socket Relocation Kit. THe kit is made of OEM BMW Parts. It is a replacement headlight switch panel with a built in power socket and a blank plug for when you are not using the socket. The power socket is in the ideal location to power a GPS unit or radar detector. Putting the socket close to the map pocket in the driver side door lets you charge a cell phone while keeping it close by. Please note that this does not add a power socket, it is meant to replace the one in the ashtray. Installation is a breeze. |
