06-22-2009, 03:22 PM | #1 |
Rep 7,389
Dinan Camber Plates
Has anyone installed the Dinan camber plates on an E9x M3? I'm considering it and was wondering how much negative camber you were able to get on the front.
Also, does anyone know of any other camber plate options out there that'll work with the EDC? My autocross class is heating up and I need better turn-in. Also, the M3 could use more tire at the rear, since I could spin the tires at will anywhere on the AX course. Dave
06-22-2009, 03:48 PM | #4 | |
Rep 7,389
Dave
06-22-2009, 03:48 PM | #5 | |
Rep 7,389
Dave
06-22-2009, 03:57 PM | #6 |
Rep 8,033
Yes, the car rotates more freely. You don't need to fight it as much turning in. And I have EDC. I am seeing even temps and even wear on the track across both front tires, so I don't know that the car needs more than this.
06-22-2009, 04:07 PM | #7 |
Rep 7,389
Thanks Lucid.
Sparkyg, I found the thread and the guy didn't have the Stage I spring kit that the plate is designed for. I DO have the spring kit, but that is still a good heads up for anyone considering a camber plate w/o stiffer and lower springs. Dave
06-22-2009, 05:51 PM | #9 | |
Rep 7,389
Dave
06-22-2009, 06:18 PM | #10 |
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
I got -1.7° with the plates and springs and the pins in place. Best part is no added NVH.
06-22-2009, 06:19 PM | #11 |
Rep 7,389
After rereading the descriptions at Dinan, I think that the springs may well be the same in Stage I, II and III and the differences being that II includes the sway bar and III includes the sway bar AND camber plates. The sway bar size is the same in all cases.
So that brings up another question. Has anyone used the sway bar? Dave
06-22-2009, 06:21 PM | #12 | |
Rep 7,389
Dave
