06-23-2009, 06:31 PM | #1 |
Rep 32
iPhone/Smartphone snap-in adapter info
I went from the original iPhone to the new 3G S that came out last week, and thought it was time to get the snap-in adaptor:
Apple iPhone 3G USB Snap In Adapter for BMW Smart Phone (PN: 84 21 2 151 043) for $175.00 Picked it up today and realized you also need the "6NF optional smartphone base" otherwise there's nothing for the $175 part above to fit into (unless it was already available in your vehicle when you purchased it.) According to Rasmussen BMW parts dept, there is only ONE 6NF available in the US (somewhere on the east coast) but 200+ in Germany. So, hopefully I'll get mine in 5+ days and can post photos of the DIY install. I'll note that they have not yet installed this for any 135i, and at first did not think it existed--until I provided the part number above, found on the accessories.bmwusa.com Web site: http://accessories.bmwusa.com/Access...px?modelId=444 Anyway, I've found little detailed information on the Web about this (specific to the 135i) so I'm posting this here and hope to update later with photos, etc. |
06-23-2009, 08:23 PM | #2 |
Rep 239
Honestly, save your money and your time. I got the dealer to throw the adapter and the smart phone prep for free when I bought the car. So glad I did not pay for it.
Still get the "accessory not designed to work with iphone" message when I plug the phone in, reception is no better, and the audio quality is not as good as with the regular usb adapter, so basically all it does is charge the phone. There is another thread on here also highlighting the many shortcomings of this accessory. Might be worth a read. Good Luck TJ |
06-23-2009, 08:59 PM | #3 | |
Rep 13,019
They should have known this as it has been announced since the 6NF introduction: this is a factory option only, no accessory retrofit available. The correct snap in and baseplate for your car is the non-6NF accessory, the regular phone snap in accessory for the iPhone. |
06-23-2009, 09:52 PM | #4 |
Rep 102
Does the non-6NF snap in adapter connect the car to the usb/audio in so that the iPhone can charge and play music like normal? Also, how hard is it to install and where do the cables go to get into the armrest (if there are cables to connect it to usb/audio in)?
06-24-2009, 05:36 AM | #5 | |
Rep 32
Thanks. |
06-24-2009, 07:07 AM | #6 | |
Rep 13,019
I strongly advise you to double check these P/N with a dealer other than the one that ordered the incorrect parts. These P/N are from www.realoem.com/bmw and they are behind the latest P/N updates for at least 5 months, so changes to these P/N could be possible. |
06-24-2009, 07:12 AM | #7 | |
Rep 13,019
The connection harness is located under the parking brake boot; installing the baseplate/eject box and the snap-in with that harness in the center console is a 15 minute job. |
06-24-2009, 09:13 AM | #8 |
Rep 102
So what do I need to buy to install the regular snap in adapter? Is it just the snap in adapter or do I need to buy the baseplate/eject box? If I need to buy those, where do I get them or what is the part number? Thanks for you help!
06-24-2009, 10:00 AM | #9 | |
Rep 13,019
09-19-2009, 07:56 PM | #10 | |
Rep 586
2009 135i Black on Black
Options|Leather| Sport Package| Premium Stereo| Steering Assist | V1 Engine MODS| JB4 install | AR DPs | Berk Axleback | ITG Filter | BHS OCC | Exterior Bling| Kerscher splitter | Interior Bling | Bimmian pedals | 3P Cars gauage | |
09-30-2009, 09:52 PM | #11 | |
Rep 9,156
i just got my iphone and i want a cradle setup to charge it. i don't really care for playing music from my iphone so i'm going with the standard snap in adaptor. also my car does not have the 6NF option from factory as we didn't have that option when we ordered. do i need anything else? install? |
10-01-2009, 01:06 AM | #12 |
Rep 98
Drives: X6 XDrive35D
Having a 3gs I was ready to go down the path of attempting to fit the cradle into the arm rest then I realised that a large part of iPhone features would be lost as it's not easily viewed or accessed in the oem location. For me it's all the driving related apps that make the iPhone require a more line of sight location such as satnav etc.
11-05-2009, 11:26 PM | #13 |
Rep 9,156
So I picked up my snap in adaptor for my iPhone 3GS today. Very easy to install, just remove the plastic try and it clicks straight in. The smart phone integration option was not available as an option from factory when I ordered the car so I am not able to play music from my iphone 3GS. You need to have specified this option from factory if you want to use this function.
It does however sit in the arm rest very nicely and it charges my iphone which is all I wanted it for. I have a 32GB flash stick plugged into the USB slot which I leave in the car permanently and it plays all my music flawlessly and has more than enough space. This works well for me as I never plan to leave my iphone in the car and if somebody ever breaks into my car all they will steal is my USB stick which can be easily replaced. There was no 'warning message' or 'airplane mode' message when I plugged it in, the snap in adaptor works a charm. Very happy with the purchase and I recommend it to anyone who needs a dedicated place to put their iphone and keep it charged while driving. I am yet to properly test out the sound and reception quality because I'm told by using the snap in adaptor it uses the cars external antenna. I made a quick call and it doesn't seem any better, which isn't a bad thing because it worked fine before. |
11-06-2009, 08:42 AM | #14 |
Rep 197
That's a relief, knowing it definitely charges the phone (I have a 3GS). I did order my 135i with Smartphone integration, sounds like it will be very slick! Thanks for the mini-review.
11-06-2009, 11:52 PM | #15 |
Rep 146
ordering tomorrow with smartphone integration for my iphone
If I understand correctly there's an iphone-specific adapter required... Is it for software compatibilty? Or just to physically mount the phone?
2010 135i Coupe | Black Sapphire Metallic | Red Leather | Poplar Grey Wood Trim | 6MT | Premium pack | M Sport pack | Heated Seats | HK Premium sound | USB | Smartphone integration | Automatic high beams
11-07-2009, 01:53 PM | #16 |
Apex Everything!
983
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
It's just to mount the phone.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
11-07-2009, 04:03 PM | #17 |
Rep 9,156
The snap in adaptor is the term used for the cradle or dock used to mount your phone. It's the actual piece of plastic that goes in your armrest that allows you to click your phone into it. Without this you would have an empty space in your center arm rest.
11-08-2009, 12:25 AM | #18 |
Rep 146
OK, my car (when it arrives) is configured with BMW Assist/Bluetooth, the 6FL iPod/USB Adapter and 6NF Smartphone Integration options. To paraphrase the accessories catalog, my expectation is that this will enable me to charge the phone, access music or MP3 files and connect to the roof mounted telephone antenna for improved cellular reception.
So far, so good... The accessories catalog goes on to say that "The adapter also provides a safe and secure place to dock your Smart Phone while driving and will charge your phone battery when the vehicle is running." This is where I'm looking for some first hand experience. My specific question is around iphone covers and whether there are any covers that are compatible with the snap-in adapter. The pix and description make it seem likely that only the slimmest of covers would have a chance of fitting into the snap-in adapter. I guess I need a better understanding of the "empty space". If I can find an alternative approach for securing the iphone, will I be able to plug in without the snap-in adapter? And, will I still get all the benefits?
11-08-2009, 02:31 AM | #19 | |
Rep 9,156
The only possible way to charge any type of phone is to plug in a connection into the battery power source of the phone, I can't think of a phone that can charge itself without doing this in any situation. In your situation if you get into the car and leave your iphone on your car seat you will retain all the benefits of bluetooth and be able to answer/take calls. However, you will not be able to charge your iphone as it needs to be docked to do this, there needs to be a power source. I believe this is the case with accessing music from the iphone as well unless option 6NF allows you to play it through bluetooth, I am not too sure. In response to your question about a case for the iphone it would seem that there is not enough room for a silicon or leather case so you would have to remove it before docking it. I don't have a case for my iphone but I have an anti-glare film which covers the screen of my iphone to protect it from any scratches and this is not an issue at all. I have attached a photo, hopefully it clears things up for you. |
11-06-2010, 01:30 AM | #20 |
Rep 567
I am in the process of unlocking an iPhone 4. Got it jail broken so far. (so it is a fancy PDA...). Has anyone tried fitting the iphone 4 into one of these adapters?
11-06-2010, 06:15 AM | #21 | |
The Only Sane One Here
61
Rep 1,135
BMW still hasn't released an iPhone 4 version?
2011 135i VERT SGM/SB/MOONLIGHT - ED - with every single friggin' option they offered.
