08-05-2009, 07:44 PM | #1 |
Rep 2,867
Question about bbs lm, spacer and rubbing.
My rears are 19x10 and I am dropped on H&R's, offset is 25. Tire size is 285/30. My question is, If I run a 12mm spacer, will I have rubbing issues? right now I have a 5mm on there with absolutely none, even after hard cornering. Do u think i would have issues with the 12? I want the flushest look possible.
08-06-2009, 09:22 AM | #2 |
Rep 3,039
your wheel and offset already extend 5mm and the 5mm spacer brings you to a 10mm extension.
My rears 10.5 width +25 offset extend 11mm and I rub very occasionally with a passenger in the back in the stock suspension. Although I'm running 295/30s so my side wall is 3mm more around or .11 of an inch. My tires are also PS2s which have the highest sidewall of the tire brands. |
