BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > Australia
European Auto Source (EAS)
      08-14-2009, 08:10 AM   #1
amk2912
amk2912's Avatar
Australia
87
Drives: '10 X5 40d & '12 F10 520d
Does your car make squeaky noises around the windows?
My E90 squeaks quite alot around the doors where the glass butts into the frame. It's becoming annoying now - winding the windows down a bit reduces it a bit but I can't accept that this is normal. Has anyone else experienced this? My late 135, 130 and 530's were tight as and didn't have this issue.
      08-14-2009, 09:32 AM   #2
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Car with a 'window frame' will be alot less likely to squeek than those without like the E92.
You're absolutely right, if you ease the pressure it helps.
      08-14-2009, 10:07 AM   #3
davem3fan
davem3fan's Avatar
Drives: 2011 M3 Sedan
Put REJEX or something similar on the black trim at the friction points...
The frame still creak with the doors open, but when shut, its much quieter.
Dave Flogaus CCA #123862
11 E90 M3 Sedan DCT
94 E36 325is M-Tech (S50)
m3post
