08-23-2009, 10:36 PM | #1 |
Rep 448
Trickle Charging
My vehicle often sits for long periods unused. What's the best procedure for trickle charging? If the trunk is left open, the trunk lights use some of the charge. If the trunk is closed, is there risk of battery gases igniting?
Thanks. |
08-23-2009, 10:44 PM | #2 |
Rep 786
You can hook up under the hood too; where the jumper connections are. This avoids connecting in the trunk.
'09 135i 6MT : Space Grey/Black ette : Cold Weather Package : Sport Package : Glacier Silver Aluminum Trim : iPod and USB : Nav : HD radio : Premium hi-fi system
08-23-2009, 10:53 PM | #3 |
Rep 448
Thanks and question
08-23-2009, 10:57 PM | #4 |
Rep 786
There is a red cap over the positive terminal to your left when looking at the car and a ground knob/lug looking thing near it. That's how I hook mine up. Then I put a couple of pieces of cardboard over the wire near the latch and semi-close the hood.
08-24-2009, 07:34 AM | #5 |
Rep 1,416
Drives: M-Sport 128i, 328xi, 3.0CS
The CTEK MULTI US 3300 charger/maintainer is the one sold by Porsche. It comes with an adapter to plug into the cigarette lighter socket so you don't even need to open the trunk or hood.
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
08-24-2009, 10:23 AM | #6 | |
Rep 786
08-24-2009, 11:34 AM | #7 |
Rep 1,416
Is there enough give in the door gasket to close over a thin extension cord?
08-24-2009, 10:15 PM | #8 |
Rep 786
I wouldn't want to chance fraying the cord, and would be annoyed if there was an indentation in the gasket when cleaning. Yes I am that spastic.
08-25-2009, 03:01 AM | #9 |
Rep 98
Drives: X6 XDrive35D
I don't think the cigarette lighter socket is permanently live so will only allow charge when ignition is on. A feature of modern canbus cars which can be a pain in the ass.
08-25-2009, 06:23 AM | #10 |
Rep 3,350
You could also use a solar flat panel trickle charger - if your car is visible to sunlight during the day. You could leave the flat panel on the rear parcel shelf and run the cable through the rear seat direct to the battery. These are small amperage (5 watt, less than 1/2 amp) trickle chargers, and would not cause any gas build up.
08-25-2009, 12:57 PM | #11 | |
Rep 1,477
You need to connect the trickle charger to the posts under the hood. In the owner's manual look for the section on how to jump the car. That will show you a picture of where to connect the clips. |
08-26-2009, 06:36 AM | #12 |
Rep 3,350
05-18-2016, 08:43 PM | #13 |
Rep 286
For those of us with the Ctek charger- I believe it needs to be connected directly to the battery. Is anyone using this under the hood? I ask because the cord itself will not stretch between the posts - it's meant for the size of a battery. I miss my Z4M which used the cigarette lighter option!
2011 - 1M - Black
2007 - Honda S2000 - Black 2020 - Lexus GX460 - Black 2022 - Lexus ES350 - Black Last edited by etr2016; 05-18-2016 at 10:09 PM.. |
05-18-2016, 09:44 PM | #14 | |
Thread killer
646
Rep 1,896
05-18-2016, 10:10 PM | #15 |
Rep 286
Admittedly, I haven't looked under the hood much - but on my Z4M the charging ports were so far apart the CTEK wouldn't reach. Clearly I need to take another look under the hood...
2011 - 1M - Black
2007 - Honda S2000 - Black 2020 - Lexus GX460 - Black 2022 - Lexus ES350 - Black |
05-18-2016, 10:53 PM | #16 | |
bimmerphile, technogeek
998
Rep 3,785
Drives: 2012 E82 6MT Sport
My setup:
05-21-2016, 09:01 PM | #17 |
Rep 286
2011 - 1M - Black
05-21-2016, 09:09 PM | #19 |
Rep 1,850
Use some common sense dude. Your car charges the battery while it runs. If you can't work out the implications of that, then I'll tell you that the battery has a tube attached that vents any gas outside the vehicle.
05-21-2016, 09:20 PM | #20 |
Rep 448
Too late. He died 7 years ago shortly after posting what you're trying to debate...
05-21-2016, 10:18 PM | #21 |
Rep 1,850
05-21-2016, 11:49 PM | #22 |
998
Rep 3,785
Yup.
I think it's a more positive connection than using the clamps... And the quick disconnect on the cable has a waterproof cap on it.
