BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      08-31-2009, 12:49 PM   #1
e90mod
Drives: M3/4 Family sled!
Any DIY on M3 swaybars?
Or is this not really a DIY-er...better for a true mechanic?
      09-01-2009, 12:06 AM   #2
ase2dais
//Mdicted
ase2dais's Avatar
Drives: a Cop Magnet
if this is anything like my last e90, which i believe it is, it involves dropping the rear sub frame to install the aft sway.. the fronts are ez. The rears are a Mother!@#$
but there is a technique to get around it, but i wouldnt do it as a backyard mechanic. I gave the tip to my mechanic and he got it right away and was able to do it all in 2 hrs, which normally would be a 4+ hours job
      09-01-2009, 07:08 AM   #3
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
How much do sway bars cost to install on our cars?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      09-02-2009, 02:21 AM   #4
schnell325
Bored at work....
schnell325's Avatar
Drives: 2016 F82 M4 GTS//2022 M235iGC
Someone has swaybars for the M3?
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      10-05-2009, 10:17 PM   #5
JuniorDee
JuniorDee's Avatar
74
Drives: the speed limit
I bought the e93 sways and installed the front. Pretty straight forward to install. Havent done the rears yet due to the whole sub frame issue
EDC.....viagra for your car
      10-05-2009, 11:05 PM   #6
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Front is quite simple. Just drop the reinforcement plate and the bushings and you are done. The rears... don't do it. You don't want to mess with factory aligned suspension subframe just for a sway bar...
If you really want to do it, make sure a good, certified body shop aligns the subframe for you.
m3post
