09-11-2009, 08:40 AM | #1 |
Moderator
7525
Rep 19,368
M-DCT Park->Reverse question
Anyone else find that there is a slight delay after the car is started up where the transmission won't engage R yet? This is an extremely minor point, but still an annoyance.
Ever since my startup routine has become more second nature, I have found that the time it takes for me to move my hand from the start button to the shift lever and engage reverse is not quite long enough for the transmission to get "booted up" (for lack of better term) and allow reverse to be selected. As a result, while the stick has definitely been moved to the R gate, the dash computer still reads P and the car is still in park. I then have to disengage the shifter from the R gate and then reengage it. Anyone else notice this? I wonder why this happens? I think that, once the transmission is "awake" it should just notice that the car is R and then properly engage R. I shouldn't really have to disengage/reengage the stick, IMHO. Although, maybe that is an artifact of the car not allowing you to start it while the stick is in R position? I honestly don't know if that is the case or not - never tried it. Even if so, it still seems like it should just select R as long as the stick is in position and my foot is on brake and the engine is running. |
09-11-2009, 10:09 AM | #2 |
Rep 3,452
Not sure, but I have heard from a few sources that you should always give the engine 8 - 10 seconds of idling before engaging a gear. If the engine is cold, I always wait for the revs to decline before engaging a gear (45 - 60 seconds).
09-11-2009, 10:59 AM | #3 | |||||
8300
19
Rep 573
... of course if you have a 6MT you can rock your car back and forth much faster than with a DCT ... |
09-11-2009, 11:28 AM | #5 |
BMW Individual Junkie.
99
Rep 478
I have this problem and I find it quite an annoying. But its really only a minor issue, like you said. Something I can easily live with.
///MYKE
09-11-2009, 10:53 PM | #8 |
Rep 1,113
it happens once in a while for me too. i just put the car into gear (d1 or s1) and then move back to reverse and it will engage. just a little quirk of the car. no big deal to me.
