09-17-2009, 06:14 PM | #1 |
Rep 1,429
Quick! Help Needed
I know this is in the wrong forum, but more people will see it here.
Is this a permissible spot to use jack stands in the rear? The elbow just to the right of the muffler bend.
09-17-2009, 08:23 PM | #2 |
Rep 5,012
Yep! Rock solid, but unless you have those jack stands with round pads, I wouldn't get under the car without additional 'backup' support (like another pair of jack stands under the jacking points, or a jack under the differential). The regular jack stands are too narrow to be stable over a round surface.
I used those locations when cleaning the rust on the wheel hubs, which obviously required wheel removal. But left the floor jack under the differential like an inch below, as a precaution. When not needing to remove the wheels, like to remove exhaust, I jack up the rear from the differential (like you), but place the rear on rhino ramps instead (don't like to wear my clutch, or risk overshooting the ramps ), since I wouldn't be able to work with the jack under the differential. Hope this helps. |
09-18-2009, 12:48 AM | #3 | |
Rep 2,426
“For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.”
- John 3:16 |
09-18-2009, 10:30 AM | #4 |
Rep 1,429
Good stuff. The stands are taking the load, but I have the jack up against the diff just in case. Thanks for the help
09-18-2009, 11:26 AM | #5 | |
Rep 5,012
Hey, may I ask what were you doing down there? Exhaust, perhaps? |
