09-24-2009, 12:12 PM | #1 |
Rep 1,139
best front plate solution
What do you guys think....should i go w/the rho plate or skene design solution on an e92?
or was there another solution available as well? recently too many people i know have gotten pulled over for no front plate in ny and nj thanks |
09-24-2009, 12:40 PM | #2 | |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
Hope this helps....
I did see someone use the stock plate holder but drilled holes on the bottom and 3M'd the rest of the holder to the front bumper. Then you could remove in the future and still have a bumper with no holes! LINK: http://www.gominigo.com/NHLPB-BMW.html There was a guy on here who used some industrial velcro with a custom bracket:
09-24-2009, 02:09 PM | #6 |
Rep 724
Blue car: Why does it look like the hood is ajar on one side?
White car: Looks like a "buck tooth", and wouldn't that block vital air flow? maybe drill holes throughout the plate to allow air flow Velcro solution: So when do you put it on/take it off? Don't put it on until you get pulled over OEM Solution: Makes the most sense if your state requires it. My solution: Move to a state that doesn't require it, or somehow register your vehicle in another state (it's been done). Regards, Dale
Mmmm... M&Ms,
Dale |
09-24-2009, 02:12 PM | #8 |
Rep 6,007
I got tow hook solution... I never use it unless going on a long road trip, or known places where they check for front plate like NYC. Other than that it stays in the trunk of my car.
09-24-2009, 03:01 PM | #9 | ||
Rep 2,775
Drives: F95 X5MC
BTW, I haven't used the gominigo plate holder yet; I plan on using it for NJ state inspections.
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
09-24-2009, 03:02 PM | #10 |
Rep 273
Drives: 2009 IB M3 Coupe
Best solution = nothing.
2009 M3 coupe,interlagos blue,6mt,loaded,19" hre comp 97s,powerchip,h&r springs,hamann front splitter,eisenmann race exhaust
Delivered 7/10/09 |
09-24-2009, 03:16 PM | #12 |
Rep 423
09-24-2009, 05:32 PM | #15 |
Rep 5,069
I linked to photo straight from their website. I hear royalties......!
09-24-2009, 05:56 PM | #16 |
Rep 5,012
Folks, the car ALREADY HAS the holes for the lower part of the front license plate holder, and are completely out of sight. But instead of drilling the upper holes in the bumper, I'd just use double-sided tape to avoid the holder hitting the bumper and scratching it, and also to prevent bouncing, but the bottom 2 screws are more than enough to secure the holder. Therefore, I wouldn't use industrial strength tape, like on badges, since it'd be a b*tch to remove on that location (compared to badges).
I live in TX, and haven't used a front plate in my 25+ years here, bit if I ever have to, will just use the stock holder as described. Good luck OP. |
09-24-2009, 06:00 PM | #17 |
Racying Dynamics
118
Rep 4,391
Christ, either take it off entirely or "Velcro" it on so that it can be taken off as soon as you clear certain areas. But for sure not on the side.
09-24-2009, 09:17 PM | #19 |
Rep 754
I just got one of these for my 1er. It works great! It screws-in to the tow mount, and doesn’t even touch your bumper. You can put it on and off as much as you want.
http://stores.homestead.com/BallistaInc/StoreFront.bok He is a Porsche guy, but he also makes them for BMWs… He told me that he has a lot of clients with M3s. |
09-24-2009, 09:25 PM | #20 | |
///M 5light
248
Rep 439
09-24-2009, 09:35 PM | #21 | |
Rep 754
It may look at little awkward in that spot, but it is better then drilling holes in your bumper. The best part is that you can take if off when you get to an event to show-off your car, and then put it back on for the drive home. |
