10-16-2009, 10:34 AM | #1 |
Rep 8
Acceleration issue
Hi all. I'm new here. A few months ago, I took delivery of a new-to-me 2008 E93. It replaced my beloved E36 M3C.
I'll be taking it into the dealer for this as well as a very annoying acceleration issue, which I need to see if others on this forum have experienced. While I love this car, I'm second guessing myself for buying it used. My E36 was purchased new (and at the end of the model run) so it was darn near perfect (they had 7 years to work out issues). I'm looking forward to learning a lot from you all! |
10-16-2009, 10:47 AM | #2 |
Rep 5,483
welcome to the forum,
what sort of acceleration issue are you experiencing??
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
10-16-2009, 11:14 AM | #3 |
Rep 8
I don't want to hijack this thread, but you did ask. If we need to, can this part of the thread be moved into a new thread?
On a cold start and while slowly accelerating (say, down my cul-de-sac or out of my office park), the car will "buck" (it's a pretty severe and violent forward/reverse shake of the entire car) a few times starting at 2700rpm through about 3k rpm. It happens pretty regularly, although it's not 100% reproducible. I took it to the dealer once, left it overnight, and they couldn't reproduce the issue the next morning. They analyzed the gas and said it had 13% ethanol which they think may contribute to the issue. I don't buy that as I only put in premium brand gasoline (ExxonMobil, Shell, etc). They also reset the "adaptation values" since the car was new-to-me. For a few days, it helped mitigate the issue. Starts were much faster and the shake was reduce tremendously (although not 100% fixed). But, the problems quickly returned. I found that if I rev the engine past 3K before I take off, the problem tends to not manifest itself. But, I've also had this type of issue when I'm trying to accelerate somewhat quickly (say, trying to turn into cross traffic). I think these 2 events are related. And, I also found that when the car begins to "buck", if I step on the clutch (I have a 6MT), the car immediately stops shaking. *Usually*, the problem is solved for that driving session, but I've had it immediately happen again 1-2 more times. Needless to say, this is an extremely annoying issue. While I have a workaround (revving the engine), I don't think I should have to do this. I'm going to keep making appointments, leaving the car overnight, and then going there first thing in the morning so that I can drive the car with a SA or a tech until one of them sees the problem first hand. Between these issues and my leaks...I'm really not enjoying this car as much as I should be. |
10-16-2009, 12:01 PM | #5 | |
Rep 8
I've been driving a manual for the past 10 years with my E36 M3, and then a few years with a 325i before that, although I did take a good 6 years off when I was driving my Chevy. You don't even need to shift. Put the car into first, slowly accelerate to 2700 and enjoy the shake. |
10-16-2009, 12:08 PM | #6 |
Rep 1,314
Well, this is pretty normal on many manuals when cold. I see it on my E93 M3 for maybe 2 minutes after a cold start, and get around it by modulating clutch and throttle, as you seem to have learned. I've experienced it on many other manuals as well, including my RS4. The reason the dealer couldn't find it was they likely thought it was normal and didn't notice it while using the right technique, or they warmed the car up for more than 2 minutes before driving it.
This engine is not a torque monster down low, as opposed to something like the LS7 in a Z06, which would pull in 4th gear at 2K rpms from a standing start. When cold, it will balk even more without a few more revs. Bottom line is, I don't think you have a problem. If you think that 2 minute inconvenience is a major problem, I'd be worried about you.
10-16-2009, 12:21 PM | #7 | ||
Rep 8
Seeing how you haven't seen how my car behaves, it's possible that we're talking about 2 different things. If this were truly an issue that "many or most" cars with manual transmissions have, then resetting the adaptation values should have no effect. To me, it seems like there's something related to fuel supply that is causing the problem. Many have suggested it could be a faulty temperature sensor. One mechanic friend said his wife's car had a similar isssue. For him, reflashing the software solved it. Thanks for your input. I'll repost this in its own thread, as this really doesn't belong in this thread. |
10-16-2009, 12:23 PM | #8 |
Rep 1,314
I don't know what you're describing as a "violent shake." You seem a little prone to hyperbole. If your clutch technique is awful, I could see you getting a pretty good jolt.
I see a lot of drivers who think they know how to drive a manual, and when I ride with them, I'm surprised at how bad and massively jerky they are. At any rate, you said it was a 2 minute issue, and you knew how to prevent it with driver technique. What is the problem?
10-16-2009, 12:29 PM | #9 | |
Rep 8
As I mentioned, it has nothing to do with shifting. I can keep the car in first, shift to second... it really doesn't matter. But as soon as the engine hits 2700rpm, the shake happens. But, nothing I say will convince you that the car itself actually has a problem. And, there's no way for you to see the problem for yourself. So, there's no point in continuing with this conversation. Thanks again for your input. |
10-16-2009, 12:38 PM | #10 | |
Dog Listener
707
Rep 7,850
It takes a certain "art" with the clutch/gas to avoid looking like you're 16 and driving your first stick. I can, if I want to, easily make the car buck like a bronco when it's cold. I can't reproduce that effect very easily when it's warm. Not that I'd want to do that in either case that would mean my technique needed improvement. The only software flash I know of that would "fix" this is the AA flash which eliminates the "heat the cats" cycle. |
10-16-2009, 12:44 PM | #11 | |
Dog Listener
707
Rep 7,850
Then again, since we're not riding in your car, there may be some other issues or what you're experiencing may be different. In any case, I wish you the best of luck getting this issue resolved. |
10-16-2009, 12:48 PM | #12 | |
Rep 8
I do appreciate the technical details of what is probably going on. Thanks for your input, Finnegan. I'm hoping I'm now down to just one set of issues... my leaks! (trying to get back on topic) |
10-16-2009, 12:53 PM | #13 | |
Rep 8
It's comforting to know that these exact criteria can cause it for at least one other. It's harder for me to say there's something wrong with the car then. |
10-16-2009, 12:53 PM | #14 | |
Dog Listener
707
Rep 7,850
And sorry about the leaks. I don't really drive in the rain, but hand washing (two bucket + hose) hasn't resulted in a single leak. Now my (now gone) 335 coupe? That's another story! I'd always have a drop or two on the drivers side window when washing. |
10-16-2009, 04:08 PM | #15 | |
Moderator / European Editor
1547
Rep 6,754
Best regards, south
10-16-2009, 05:39 PM | #16 |
Rep 436
I've had the same problem happening once in a while since I got this car and my '06 330i before it. Cold starts in the morning shifting weirdly makes the car buck like a bronco, yes kinda violently. It is not a problem with your car.
2008 Sparkling Graphite e90 M3 6spd
10-16-2009, 06:46 PM | #17 |
Rep 24
Had to chime in here. The very first time I pulled away from the dealership in my one and only M3 test drive, I had that thing bucking like a bronco. E90M3 6MT. Thankfully, the dealer had just tossed me the keys and I was solo (that's what you get for being 40+ and arriving in a clean 550i) but it was still very embarassing until I quickly stabbed the clutch, rev'd the shit out of it and released the the clutch again slowly.
Got spoiled with my 550i 6MT for the past seveal years. You can start that in first gear with no throttle if you are careful and you can also easily start it from stop in second with slight throttle. Never bucks as it is a torque monster. But I am already preparing myself for the M3 - whole different motor that needs more revs to be smooth.
2010 E90 M3 /SG/FR/6MT...finally here...
10-16-2009, 06:55 PM | #18 | |
Rep 1,314
10-16-2009, 06:56 PM | #19 |
Rep 5,012
As everybody said, it's normal, but only if you want it to be. You can easily avoid that doing one of several things: warm up the car a bit, stay out of that rpm range in low gear, accelerate a bit harder... etc. No car is perfect, and engines don't like to run cold, so you can always expect cold fueling issues on any car. Same with motorcycles; I can make them buck like a wild bronco if I want to, but I avoid it. Consider it another challenge to learn to be even smoother on a manual . That's why I love manual cars; you can always be smoother, so it's a continuing challenge to be ever smoother and smoother with gear changes, cold engines, down shifting, rev matching, etc. You never stop learning how to improve on your manual driving .
10-16-2009, 07:09 PM | #20 | |
Rep 1,314
The quest for "smoothness" in driving a manual is an art form, and one can always get better no matter how many years of experience. I happen to have 36 years of experience on more than 50 cars, and I can still get "smoother." Moreover, every car is different, and it takes a minimum of several months to get acceptably "smooth" every time you switch rides. Now, my definition of "smooth" is off-the-charts high, and I'm sure there will be many who chime in claiming they are already "smooth." Please understand that I'm talking an entirely different level of "smooth." I sense that you understand what I'm talking about ELP. Few do.
10-16-2009, 09:49 PM | #22 |
Dog Listener
707
Rep 7,850
Foosh and elp_jc, I think I'm on the same page with you guys. Maybe I'm a "chimer"--in any case here's my definition of smooth:
MT nirvana is when you're passengers have trouble telling you've shifted up or down (other than engine speed); revs match perfectly up/down and there's no sense of change in the motion of the car. Almost "DCT" like if you want to put it that way. That's what I consider the black belt level of smoothness.I haven't reached that level yet, but after 30 years of driving a stick I have periods when I'm 100% focused where I can row up and down through the gears for short periods of time where it's like there's no gear changes (other than change in engine speed) occuring at all. This is by no means consistent, but there are small windows into how it could be if I continue to strive for it. I can hit the zone more frequently for longer periods with my DD, which I've got 165K miles on and 12 years of driving in. I replaced the original clutch at 156K miles which I hope speaks to some level of "smooth". I'm sure I'd not pass the "Foosh test" but I think I might have hit some decent white belt level of smooth. With the M3 I've got the cold starts mastered most days. No bucking bronco action. But I've still got a way to go with being happy with even a white belt level of smooth for most driving. It's better the more I drive the M3. It seems like the goal of being super with each car I drive is always just out of reach, and trying to reach it is part of the fun of a MT (for me). All this said I'm not sure I'd want either of you in the grading my performance--I think you guys are probably more at the black belt level ! |
