10-19-2009, 04:24 PM | #2 |
Rep 2,148
From what I've seen Eibach has a conservative drop enough to fit wider tires without the rubbing. I'm leaning towards Eibach springs as well for that same purpose.
10-19-2009, 04:53 PM | #3 |
yodog
197
Rep 5,025
Yes, but check on your offsets/wheel width/tire width if you're going 285/35/19 or 285/40/18 in the rear.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
10-20-2009, 11:27 AM | #4 |
Rep 91
I'm running 275/30/19 F, 295/30/19 R, on H&R with no rubbing issues. (HRE wheels)
If your going with wider tires just stick close to the stock diameter and you shouldnt have a problem i.e. 275/35/19 F would definately rub. If your usimg stock wheels you will have fewer choices in a safe width. As Mr Harris said, offsets will matter too |
10-22-2009, 07:24 PM | #6 | |
BimmerPost Supporting Vendor
8268
Rep 18,855
Shouldn't be a problem at all.
03-22-2010, 03:45 AM | #8 |
yodog
197
Rep 5,025
What about 285/35/19 with those same specs of wheels?
