10-23-2009, 07:31 PM | #1 |
Rep 1,805
Drilled vs Slotted?
what are the different effects of each? what are pos/neg of each? Am looking at brembo bbk kit. What would you get?
17' M2 DCT - KW CS - Re71r - Carbotech
BW C13 - 1:57:2 ACS - 1:49:6 WSIR - 1:30:6 |
10-23-2009, 07:34 PM | #2 |
Rep 1,314
Slotted is better.
In earlier days, cross-drilled was viewed as providing better cooling. Over time, experience has shown that heavily-used cross-drilled rotors can develop cracks emanating from the holes and propagating across the disk. You don't see many track cars with cross-drilled disks these days. They are more about "bling" now.
10-23-2009, 08:02 PM | #3 |
Rep 8,077
Drives: 11 E90 M3 Individual
Street and bling - drilled
Track - slotted
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
10-23-2009, 09:01 PM | #4 |
Rep 9,034
To add to what foosh said, back in the old days, there was concern about pad's "gassing out" as they wore away, where gas would form between the pads and the disc, which could then separate the disc from the pads. The cross drilled rotors were suppose to allow a place for the gases to escape. Newer pads don't gas out anymore... at least that's what I've read.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
10-25-2009, 08:18 PM | #6 |
One mod leads to another ...
419
Rep 2,900
I have always heard the same thing but does anyone actually know of someone that has had problems with drilled rotors? Here are some supercars that come with drilled rotors.
Corvette ZR1 Porsche Carerra GT and GT2 Lamborghini's Ferrari's Pagani Zonda Audi R8 I am not sure if there are any that come with slotted rotors. So if all of these cars come with drilled how bad can they be?
Current: 2014 F10 M5 Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3 |
10-25-2009, 08:27 PM | #7 | |
Rep 1,314
However, experience has shown that slotted is a better technology because of the cracking issues seen in cross-drilled rotors subjected to continuous very heavy use. It's not likely that even 1/10th of 1% of users of cross-drilled rotors will ever see a problem. They have now become the "bling choice," and the average buyer expects them in high-performance cars, so that's why you see them. Nonetheless, if I were going to spend a ton of money on a BBK, like Brembo, I'd choose the slotted option, unless it were insanely more expensive, in which case I'd be fine with cross-drilled. That's all . . .
10-25-2009, 08:37 PM | #8 |
Rep 2,278
I chose slotted rotars because the reason I upgraded the brakes is that I frequently attend HPDE (track) events. My stock rotars are warped after about 10 track days.
2015 f80 M3, 2016 GT3
10-25-2009, 08:44 PM | #9 |
Rep 1,314
In fairness, you'd have to compare slotted vs. cross-drilled of the same manufacturer, such as Brembo, as well as comparable size and spec. Your warped crossed-drilled OEM rotors weren't likely because of the cross-drilling, per se.
The cross-drilling issue is associated with rotor cracking, not warping, as I understand it.
10-25-2009, 08:44 PM | #10 | |
Rep 6,107
Drilled look better, and how many people do you know who tracks their Lamborghini's, Ferrari's hard core ? I don't know many Here is a real super car Last edited by doba_s; 10-25-2009 at 09:55 PM.. |
10-25-2009, 09:13 PM | #11 | |
Rep 2,278
10-25-2009, 10:47 PM | #12 |
Scared money don't make money.
68
Rep 1,448
Drives: 2009 E92 M3 DCT
I've seen NUMEROUS BBK kits with cracked cross-drilled rotors from too much track useage. With that said, these were Time Attack cars, not street driven cars tracked once or twice a month.
2009 E92 M3/DCT/Alpine White/Fox Red/Carbon Leather OE Tuned 402 whp & 303 wtq/Gintani X-pipe/MXP Axle Back/Rogue Pulley/AFE Stage 2/Cosmetics By IND & EAS HUGE THANKS: Gintani, OE Tuning, and EAS |
10-26-2009, 10:53 AM | #13 |
Rep 2,339
I had drilled rotors on my last car which I never tracked. It was a daily driver and towards the end of the rotor life, I did start to notice the hairline cracks around the holes. They were small enough not to be worried about them but I can imagine what they would have turned into had I tracked the car.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
10-29-2009, 06:42 PM | #14 | |
Brake Maven
Rep 229
Drilled rotors will generally crack sooner when run at excessive temperatures (even sooner if they are low quality rotors or were drilled and finished poorly -- like stuff you see on eBay!). For 99% of people on the street, drilled rotors are not problematic. I would not recommend them for aggressive track use unless you have a nice budget for replacements or have a good sponsor! There have been actual studies to show what the pros and cons are, but I'll keep this post short for now. Slotted discs provide slightly more bite than plain-faced rotors. The slots do a fairly nice job of keeping the pads clean and free from glazing. While doing that, they also cause a little bit more pad wear. It's hard to get something for nothing... Short answer: If you are not going to track the car, either drilled or slotted (or both) is fine. For track use, go with slotted unless doing very short sessions (Time Attack) and like replacing rotors. Chris |
10-29-2009, 07:33 PM | #15 |
Rep 10,407
This forum and many of its members like technical details. We would love to see anything you can share on this topic.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
10-30-2009, 12:33 AM | #16 |
Rep 6,125
German cars tend to come with Drilled and JDM cars come with slotted more.
So as the dumbest person like me, I like putting drilled on german cars and slotted on the jdm cars. FYI, I don't track so pet boys replacement rotors will be fine for what I do. =)
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
10-30-2009, 08:51 AM | #17 | |
Bates '08 Interlagos Launch
126
Rep 1,230
Custom Exhaust Project: Bates Valvetronic exhaust: http://www.m3post.com/forums/showthread.php?t=253661 -- Exhaust Mod pics in here: http://www.flickr.com/photos/40236795@N03/
DON'T BUY Race Ready Performance electronic cutout valves. Here's why: http://www.m3post.com/forums/showthr...40#post9589740 |
10-30-2009, 12:52 PM | #18 | |
Brake Maven
Rep 229
Chris |
