11-15-2009, 09:26 PM | #1 |
4 * General
58
Rep 644
Replace subs diy
does anyone know of one?
Nissan GT-R (Sold) E92 M3 + 335 (sold) F10 535 (sold) When Driving Nice Whips It Helps To Have Nice Kix!
11-16-2009, 10:50 AM | #2 |
Rep 13,019
11-20-2009, 05:06 PM | #3 |
4 * General
58
Rep 644
where can i find a remote wire in the rear of the car so the amp will turn off when i turn the car off?
11-21-2009, 03:06 AM | #4 |
Rep 164
It should be pin 10 of the HiFi amp harness. I'm not sure on the enhanced premium sound but it should also be a thin black wire.
Apparently sometimes the wire does not output a 12V current but instead outputs a 6V current or something. If that's the case just use a variable voltage trigger like the PAC TR-7. |
11-21-2009, 09:15 AM | #5 | |
Rep 13,019
The Metra 71-9003 (left connector below) is the Quadralock connector plugged in the back of the iDrive computer. You can clearly see in the illustration below the number 13 in the face of this connector. That's the wire to tap for OEM remote signal: |
11-22-2009, 01:30 PM | #7 |
4 * General
58
Rep 644
where is the dash harness located?
11-22-2009, 05:32 PM | #8 | |
Rep 13,019
Pin 13 at the Quadralock is remote in all OEM sound systems as it is the antenna amplifier turn on signal. |
11-22-2009, 05:33 PM | #9 |
Rep 13,019
11-23-2009, 07:54 AM | #10 |
4 * General
58
Rep 644
hey thx a million without your help i think i would prolly still be in the car now trying to figure stuff out. but its all in and what a difference the woofer upgrade makes.
11-23-2009, 04:24 PM | #11 | |
Rep 164
11-25-2009, 03:42 PM | #12 | |
8 tracks of madness
62
Rep 2,735
11-25-2009, 03:57 PM | #13 |
Rep 13,019
No, it is on as long as the radio is on, a door/trunk is opened and 20 minutes after any of those are off/closed.
11-25-2009, 04:40 PM | #14 |
8 tracks of madness
62
Rep 2,735
Hmmmm. I may have to use the high level inputs to turn the B1 on instead. Do you know if the HU will still output Voltage on the speaker outputs or if it sends a signal when you unlock the car? The RNS-510 does and because of that it makes a pop when you start the car. Really want to avoid that this time around.
11-25-2009, 04:55 PM | #15 | |
Rep 13,019
If you are getting an M3 then you should use the low level inputs of the bit one.1 anyways as the OEM HU/iDrive ouputs are low level balanced. Even the new high level ouputs in the MY2010 1- and 3-Series base Stereo system can be input into the low level port of the bit one.1 without any clipping. That's the way I've been running my bit one while I'm doing the 09 iDrive swap in my '08 M3. My CIC is set by default to be a base Stereo system so it outputs the same 15W per channel. The bit one.1 summing and "de-EQ" processing works as well thru the RCA inputs. The OEM remote signal turns on the bit one.1 and the bit one.1 remote out turns the two amplifiers in my system without any pops. |
11-26-2009, 01:52 AM | #16 |
8 tracks of madness
62
Rep 2,735
That's great news! Yes, I put down my deposit last night and I head over Friday to finalize the order and the loan. They have a December slot so hopefully I won't be waiting too long.
11-26-2009, 02:03 AM | #17 |
Rep 1,659
I had a 10inch Alpine sub recently fitted into the rear armrest/ski hatch.
Works very well with no loss of space. Will take photos if wanted??
M3 E93 DCT, Space Grey,BC HB29 Forged Deep Concave Wheels, Ericsson Amuse F/R Bumper, Evolve Full Exhaust System, INTRAX Coilovers, STOPTECH BBK, Performance Steering Wheel,Custom Red/Black Leather Seats,///M3 ||Bimmerpost M3 Car Of The Month May - 2010SOLD
2010 R35 GTR |
11-26-2009, 03:15 AM | #18 | |
///M South Lead
46
Rep 863
Drives: Jerez Blk / Fox Red Ext
Man you're just so full of info, what exactly do you do bro? I think like several years back you gave me the schmatics on the E46 HK setup...just wanna thank you for being a real supportive enthusiast!!
///AA ///Challenge ///MS ///EAS ///OEM ///H&R ///
MFlight!! .......NOW ///M SOUTH on Facebook!! FOR SALE!! |
11-26-2009, 04:03 AM | #19 | |
8 tracks of madness
62
Rep 2,735
He's been like this on every forum I've seen him on (3 or 4) and it's always been extremely helpful. He's good people. |
11-26-2009, 04:07 AM | #20 |
Rep 1,659
Its great, it is totally hidden unless you pull the armrest down.
Pics below
2010 R35 GTR |
11-26-2009, 07:10 AM | #22 |
Rep 1,659
Sounds great but I also have a seperate Alpine reference amplifier with it.
2010 R35 GTR |
