BMW M3 Forum (E90 E92)
      12-08-2009, 12:44 PM   #1
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
▀▄ eas | remoteKEY+ Convienence Module installation overview
Earlier this summer, we were made aware that 3-series/M3 and 1-series models with a production date of 3/09 and later were not prewired if the "Alarm" option was not specified during the ordering process. This is not new to BMW as e46 models overseas were subject to this in the past - however, most US bound vehicles were prewired.
This unique comfort controller can be installed by anyone with the help of our detailed installation manual. Installation requires little electronic skills and is done without cutting wires or soldering! The module comes with all wires and parts needed. No need for extra key fobs. Everything is done with the original key remote. The control unit was designed by our certified engineer, having years of experience on Porsche and Mercedes Benz vehicle electronics. It was developed according to all European and American (CE, FCC) directives and constitutes a state-of-the-art electronic onboard control unit. Over-voltage protection, reverse polarity protection, safety shut-off and absolutely minimal standby power drain can be taken for granted.
Product Features:
Individually programmable
Configure all functions of the module to meet your personal preferences via our signature blinker setup menu.
Factory BMW Alarm Emulation
Emulate the factory BMW alarm confirmation door locking/locking chirps and blinking LED as a visual deterrent against thieves or vandalism. remoteKEY is even compatible for 3/09+ models not prewired for the factory BMW alarm!
Passive / Invisible mode
Turn the whole module off with an easy key sequence. Ideal when letting someone else drive your car.
Reversible plug-in installation
Remove any time allowing sale or return of a leased vehicle in it's original condition.
Remote window control
Open and close the windows and the sunroof separately by remote without activating the top.
Folding Mirrors
On models equipped with motorized mirrors (premium package), fold mirrors in and out by remote. If equipped with Comfort Access -door handles can also activate mirror folding.
Automatic door unlocking
Automatically unlock the doors when turning the ignition off. No more pulling the door handle twice.
USB Port for easy updates
This module can be updated using any Windows PC / Laptop with Internet connection.
Unique design features only to be found in remoteKEY:
- Fully E13 tested and certified: E13 10R-02 4133
- Ultra-low power standby mode (less than 0.1mA)
- InstallAID LED shows correct installation and status
- Intuitive Setup menu for easy customization
Models Supported:
2006+ e9x 3-series, including M3
Installation: While the steps are quite detailed, installation should take no more than 60 minutes for the novice installer. If you are not experienced with your BMWs wiring, please consult professional installation.
Important: Remove key from ignition and negative battery cable before proceeding in order to prevent error lights from appearing during installation process.
Remove passenger side control box cover to expose DME container
Noting positions of locking tabs on lid, remove hook and slider tabs and remove cover
Remove relays and connectors from DME grid and set aside. Connectors are keyed to go back in only one direction
Slide DME from grid and set aside
Remove grid from control box, some cables may still be fastened in place by zip ties
Cut zip ties with cutters
Remove DME grid
Moving into cabin area on passenger side, remove (2) torx screws in order to remove kick panel underneath glovebox. Location of 1st torx screw
Location of 2nd torx screw
Remove kickpanel
Using a thin piece of wire or coathanger, insert wire into opening at bottom of control box to allow easier routing of cable to cabin area
Remove fuse access panel in glove compartment
Route pieze buzzer harness from glovebox to bottom side of floor panel and prepare for routing to engine area
Grab connector (2-pin) from underside of glovebox
Using electrical tape, secure wire to the bailing wire routed earlier securely
Secured connector
From engine side, slowly pull on wire until connector appears on engine side, leaving enough slack in the cabin area to plug the remoteKEY module into
Using supplied velcro, apply to piezo buzzer
Secure piezo to clear/empty sport under hood. In this shot we used the location just below the negative remote terminal
Route cable from control box underneath grommets to piezo buzzer
Connect 2-pin connector to piezo buzzer, making note of color matching
Optional: Use heatshrink tubing to lock connectors into place. Electrical/Friction tape can be used as an alternative
Apply heat to heatshrink tubing
Connection tucked away under stock wiring
Replace DME grid into control box
Replace DME computer and return harness connectors/relays to original positions. Reconnect battery.
Access wiring bundle in glovebox. Connections are as follows: Red/Yellow wire - +12V power, Brown - Ground, Twisted pair Green/Orange & Green - CANbus. Pictured is pointing to Ground wire
Twisted pair Green/Orange & Green. There will be (3) Twisted pair bundles present, use only a single pair - do not cross between pairs!
Using supplied T-Tap, fasten over Ground (Brown) wire
Using Pliers, lock T-Tap into place over Ground wire
Repeat for Twisted pair Green/Orange & Green wires and Red/Yellow. Red/Yellow wire will require (2) T-Taps, a total of (5) are used in all
Using a pick or small screwdriver, remove AIRBAG badge from passenger side A-pillar
Remove torx screw
Pull door seal from perimeter of A pillar to allow easier removal
Remove A pillar cover
A pillar cover removed, showing airbax curtain and wiring harness
Remove access panel for wiring routing, this pops out of place
Route mirror LED harness through access panel
Pull LED mirror harness through other side (correct side has bare terminal and spade connector (pictured)
Plug spade connector to Red/Yellow wire. Grey/Black wire will insert into pin 5 of remoteKEY harness, to connect with same color on other side of connector (wire not shown in connector)
Pull harness through dash opening, preparing to route towards mirror
Remove plastic mirror wiring shroud
Access mirror connector and remove from disconnect from BMW side
3/09+ Production Date: Insert red wire of LED harness into PIN8 of mirror connector, Grey/Black wire into PIN9.
2006-2/09 Production: Remove wires from PIN8 & PIN9 and insert red wire of LED harness into PIN8 of mirror connector, Grey/Black wire into PIN9. Connect mirror plug housings back together
Tuck LED wiring harness underneath headliner routing back to glove compartment
Plug remoteKEY harness into LED mirror harness, note colors are lined up correctly
Plug remaining spade connectors into harness
Connect remoteKEY harness. Blinking LED will signify CAN activity verifying a proper install
Secure LED mirror harness with zip ties, taking care not to impede curtain airbag from deployment
Return all trim panels to original positions and tuck remoteKEY module/harness away in glovebox.
Installation is complete!
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
ycb61.50
      12-08-2009, 12:45 PM   #2
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
remoteKEY+ overview:
remoteKEY overview:
Windows and sunroof can also be activated independently and has no conflicts with those equipped with CA (comfort access).
Examples:
- Setting 1 allows remote operation of the windows and the sunroof by using the original factory remote fob: Press and hold UNLOCK for 2 seconds: Open all windows
- Press and hold LOCK for 2 seconds: Close all windows
- Press and hold UNLOCK for 5 seconds: Open windows and sunroof
- Press and hold LOCK for 5 seconds: Close windows and sunroof
Features:
- Full factory alarm confirmation chirp/flashing corners/blinking mirror/LED emulation
- Remote window control: One-Touch operation of the windows and sunroof with the original remote on all models (US and Euro)
- Automatic door unlocking when ignition is turned off. Avoid having to pull the door handles twice to get out
- Comfort windows: All windows can be closed One-Touch with the wide "All-Windows" button in the driver's door.
- User programmable: The module can be individually enabled or disabled. All settings are retained even if the car battery is disconnected.
- Remote Fold-in Mirrors (if equipped). remoteKEY will fold in your mirrors on alarm activation.
- Shop/Diagnose mode: If activated the module is completely passive, as if it was not installed at all. It becomes invisible to diagnostic tools.
- End user upgradeable via integrated USB port
      01-23-2010, 01:10 AM   #3
jsport
Drives: 2008 E92 M3 AW
Probably should note that the power wires should be rerouted to a constant +12 volt power source to keep the clown nose blinking past 36mins.
      01-25-2010, 12:58 PM   #4
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Not when the power wire is hooked to permanent power, we just completed a set of alternative instructions that will be posted this week.
      04-06-2010, 10:20 AM   #5
klerk
Drives: 2014 F32
correct power source from under dash
so to clarify.....the double tap source from underneath the dash is to the red/yellow wire, or the blue/red wire? a friend used the yellow/red wire for the double tap and his rear view LED flasher did not stay on all night.
      04-06-2010, 02:09 PM   #6
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
The power wire can be found rather easily in the glovebox:
      06-06-2010, 05:33 PM   #7
SanFranFortyGiantsNiner
Drives: M3 Vert, 20" HRE, EIBACH SPRIN
2009 M3 Vert  [0.00]
You almost have me sold but one more thing I am looking for. For the 09' M3 Vert.. Can I program the vert open/closed on it as well?
      06-06-2010, 05:50 PM   #8
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
smartTOP will be what is needed for convertibles:
More info can be found here: http://www.m3post.com/forums/showthread.php?t=364065
      07-09-2010, 10:21 PM   #9
WWONG
Drives: 2012 BMW X5 xDrive35d
Okay, so my friend and I just spent the last 5 hours installing this. Everything works except for the LED on the rear-view mirror. My car is the one without the factory alarm, so do I need to purchase an LED bulb and fit it in or is it basically already idling in there (thereby meaning I did something wrong)?
      11-28-2012, 11:11 PM   #10
starbai
PPRSWCE
starbai's Avatar
Guyana
654
Drives: 18 Tanzanite Blue F80 ZCP
I know i'm bumping something several years old... but did you ever get this resolved (if ur still around lol)
      01-12-2015, 01:45 PM   #11
matrix77
Drives: E92 M3
I know this is an old DIY but how did you guys get the wires from the buzzer into the DME box? The grommets on the box for the other wiring are all sealed?
      08-02-2016, 09:44 AM   #12
Rajmun340
Rajmun340's Avatar
413
Drives: 2013 E92 M3 ZCP factory order
I am looking to make my alarm louder, i think the oem alarm volume is way too low ! If your car is outside and you're inside your house you may not hear the alarm for the first minute enough time for a tow truck thief to load it on the truck. I notice bmw sucks at everything that is electronic human interface ( radio and buttons ergonomy, idrive interface, car alarm volume..). Also the bmw oem alarm frequency is higher than others it does not propagate far and through walls.
If you're coming from a japanese car they always nail everything electronic.
m3post
