12-12-2009, 12:47 PM | #1 |
Rep 176
Dinan Springs & Alignment Issues
Just put on Dinan Springs and 12mm MS spacers all around. Car looks great. No vibration, no body roll. Feels rock solid. However, the car is now pulling to the right. The alignment shop said they aligned it per Dinan specs. Anyone else have issues after putting springs/spacers on? Is this normal?
Thanks! |
12-12-2009, 01:15 PM | #2 |
Rep 4,567
Not to hijack your thread too much, but do you mind posting pics of your car with the new drop?
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
12-12-2009, 02:00 PM | #3 | |
Rep 6,107
12-12-2009, 02:11 PM | #4 |
Rep 3,832
Speaking to my local Dinan dealer he said they were very close to stock.
12-12-2009, 03:42 PM | #5 |
Rep 6,107
12-12-2009, 04:40 PM | #6 |
Rep 8,077
Drives: 11 E90 M3 Individual
The spec are probably a little different given the different ride height. Maybe a little more front camber and a little toe? The car shouldn't pull, take it back.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
12-12-2009, 11:43 PM | #11 |
Moderator
675
Rep 4,737
Can anyone describe how hard the car is pulling? For example, when you let go of the steering wheel, does it gradualy go to the right or does it swerve to the right?
12-13-2009, 12:55 AM | #12 |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
I have no issues whatsoever with my Dinan stage 1.
12-13-2009, 01:47 AM | #13 |
Rep 6,107
12-13-2009, 02:40 AM | #14 |
Rep 176
Basically the car pulls to the right the minute you let off the steering wheel. There is also some tension to the right as you hold the car to go straight. I wouldnt say it swerves the minute you let go. Funny thing is I expected this to happen. Last car I had (987S Boxster S) I put H&R springs and it took 3 alignments to get it right..... not sure why but I hate a car that pulls. Mine ALWAYS go right. Never had a car pull left. I'm taking the M back on MOnday and getting it re-aligned ANyways, on a side note, I also went with a full AA exhaust/X-pipe. Its completely ridiculous. The best part is there is very little cabin drone or noise. It just screams when you want it to. The car also now emits some very mean burbling/back pressure noises that I love. This thing stock was just pitiful. Way too quiet.
12-13-2009, 09:11 AM | #15 |
Rep 676
I have stage 2 and it goes DOWN HILL because of increased camber ie. down from the crown of the road so in the left lane of a three lane highway it drifts left and to the right in the right lane-it doesn't drift on the crown of a one lane one way road.Dont wanna be stubborn but this could be the issue- I got used to it in a week(alot less annoying than adaptive steering!)
12-13-2009, 01:50 PM | #16 | |
Moderator
675
Rep 4,737
1) Your alignment is off. Solution: get it aligned at a BMW dealer (as much as I hate them). Dealer's tech would have more experience with these just because of the volume of cars that go through, so they are more likely to do it correctly. Dealers also have the latest equipment and alignment procedures. 2) Your tires are worn unevenly. When I had my car aligned my steering wheel was still slightly off-centered, and it was due to uneven wear between my left and right tires. 3) You may just be driving on an uneven road. As you already know roads are crowned to drain water, that's why even a perfectly aligned car may pull to the right slightly. 4) You may just be feeling the increased negative camber. Wheels with more negative camber are more inclined to turn. Add this to the crown of the road, and you car will pull. In sum, a slight pull is ok. And my definition of slight is that at highway speeds, you can let go of the wheel for a good 5 seconds and stay in the same lane. If not, then you should get it corrected. Hope this helps. |
12-13-2009, 09:42 PM | #17 |
Rep 176
Thank you very much for the input. This is definitely not a slight pull. Within 1 sec the car is already going right and it does this on the left side of the crown as well. Checked tire pressure, have brand new tires, etc. The shop is going to re-align it.
12-15-2009, 06:01 PM | #18 |
Rep 176
Took the car back to alignment shop, which has a great reputation. He went through a number of exercises and believes the car is pulling because of a tire pull and not related to the alignment specs. My question is, if the car did not pull prior to putting springs on it, and now it does, could the lower stance/spacers cause a tire pull to now appear? I also replaced the rears at the time of spring installation, fronts had plenty of tread on them. All tires were balanced. This is driving me crazy!
12-15-2009, 06:03 PM | #19 | |
Moderator
675
Rep 4,737
