12-22-2009, 08:59 AM | #1 |
Rep 441
DIY for changing MT fluid?
I searched but don't see one. If its out there, would appreciate a link, otherwise maybe someone can at least summarize the steps and give a few hints/details?
Thanks, Howard
2009 E90 328i Montego Blue, Black Leather, 6MT, ZPP, Logic 7, HD radio, CA, fold-down seats, PDC. ED pickup 6/12/2009 mods: Koni FSDs, Eibach Pro's, Sport/Heated Seats, BMW Perf. short shifter, M-tech shift knob/e-brake handle/steering wheel, split armrest, black grilles, 50% tint, 3M clear bra. |
12-22-2009, 03:23 PM | #2 |
Rep 5,012
While somebody jumps in, are you going to use stock fluid or something else? If the latter, what do you have in mind? I've been thinking of using Redline fluid to fix the cold notchiness (it cured it perfectly on my new Accord 6MT), but with BMW paying for services, am afraid of possibly voiding tranny warranty. I might do it, but want to make sure somebody else does it first and reports positive results.
As far as doing it, it should be pretty straight-forward, as tranny has both a drain and a fill plug; only extra step is removing a tranny belly pan, but should be simple as well. Only issue to watch is car should be level. You could always add the right amount, but I always prefer to wait for fluid to flow out of the fill hole, as fill amount will depend on how long you drain the tranny. I have 2 fill amounts, one 1.8 qts and 2.2 qts, and don't know which one is right. But again, it all depends on how long you drain. I'm hoping the fill plug is in the rear of the tranny, so I can lift car from the rear only. During fill up, I could rig a tubing to the engine compartment, lower the car level, fill it from there, once it flows out stop, lift car again, tighten the plug, reinstall belly pan, and be done with it. If plug is in front, I'd have to put car in ramps and jack stands, which I hope to avoid. Keep us posted man. |
12-23-2009, 07:45 AM | #3 |
Rep 441
I'd consider switching to Redline based on positive comments here. But first I need to know how to do the job
I did a post-breakin oil change using the diy here, no problem. For the MT fluid, I don't even know where the drain and fill plugs are, and right now its too effin cold in semi-upstate NY to get under there and look.
12-23-2009, 11:00 AM | #4 |
Rep 409
I have the factory instructions printed out from BMW TIS at home. I will try to scan and post. If I remember right, the instructions said something about and electrical connection required from GT1 to get all the old fluid out. I remember thinking that was odd (and wrong) for a 6MT... more like DCT.
Anyway, I will check and try to post. You can get any how-to you want for the whole car from: http://www.bmwtechinfo.com/ ... for $30 per day.
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe |
12-23-2009, 11:46 AM | #5 |
Rep 441
I have a few hours left on my 1-day subscription - where exactly do I go for the MT (and other) fluid change procedures? I couldn't find them.
Thanks
12-23-2009, 12:11 PM | #6 |
Rep 409
I don't recall of the top of my head. It would be under group 25 which is manual transmission. Not sure if that is under repair instructions or maintenance.
Jon Maddux
12-23-2009, 12:47 PM | #7 | |
I love my beautiful wife!
22
Rep 628
12-23-2009, 01:06 PM | #8 | |
Rep 409
Jon Maddux
12-23-2009, 09:59 PM | #9 | |
Rep 5,012
Strangely, Redline recommended their D4ATF for the M3, rather than MTL. They said it better matches the factory fluid. The MTL is used in earlier manual transmissions. As far as I know, nobody has switched tranny fluid so I'm eager to read the first review. OP, it should be obvious which are the drain and fill plugs. If somebody doesn't post instructions, just lift your car and post pics and we can tell you which ones. I saw them when tech was working on my 1.2K service, but don't recall from the top of my head. Good luck. |
12-26-2009, 10:41 AM | #12 |
Rep 409
See attached.
Jon Maddux
06-13-2010, 09:04 PM | #14 | |
Rep 5,012
And the good thing about doing this early is we don't have to worry about getting all fluid out, making the job much easier (and DIY, since we have no way to activate the pump ourselves). I much rather do this twice, every 10K miles or so (2 years for me) than having to empty the cooler, or letting a dealer do it. Are you using stock fluid? Please let us know when you're done, along with driving impressions (if different fluid). Good luck. |
04-22-2012, 12:30 PM | #15 |
Rep 3
I just changed the fluid in mine. Apprx 2.5 l drained out and that's also about the amount that went back in. Used Redline MTL. Also cleaned the filter screen. I don't know how to activate the pump so the lines and cooler still has old oil.
04-22-2012, 06:45 PM | #16 |
IG: limited.slip
332
Rep 1,918
Granted I haven't looked under there but wouldn't there be some kind of line that goes from the trans to the pump/cooler that we could unplug to drain the extra fluid contained in them?
04-22-2012, 08:09 PM | #17 |
Rep 3
Yes I believe the lines can be detached from the body of the trans which would allow the lines and cooler to be drained but then I'd have the problem of refilling them with fresh oil. Not having a good way to accomplish that, I did not drain them.
04-23-2012, 03:43 AM | #18 |
IG: limited.slip
332
Rep 1,918
I'm assuming we could proceed the same way you'd do an auto transmission.
So in this case that would mean filling up normally until fluid overflows from the fill plug. Then we'd start the car, go through the gears -which should work the pump and suck in the fluid- and add more fluid until it overflows again. Just a thought. In any case you'd want to keep track of how much fluid you take out so you can be sure to refill with the same amount. |
04-23-2012, 04:48 AM | #19 |
Rep 3
There is a wired sensor on the bottom of the transmission body. It appears to be a temperature probe. I'm guessing the pump is only activated above a certain temp. Running the engine while draining hot fluid might cycle the old oil out of the cooling lines but the fresh oil would be too cool to activate the pump to refill the lines; you'd have refilled the body but not the lines and cooler. Then the next time you drive the car hard and the oil got hot, the pump would activate, refilling the lines but lowering the level of the oil in the body. Not knowing how much oil is in the lines and cooler, and therefore how low the level of the oil in the would get in this scenario, I didn't try this. Of course, this is all guesswork on my part. Anyone know for sure? I'd much rather do a complete drain and refill.
04-23-2012, 06:42 AM | #20 |
Rep 71
Did the change last week. Drained about 1.7l without the oil in lines. Refiled the same ammount.
To activate the pump without BMW devices is simple. There is a powercord going into it, to activate, unplug the original cord, find somewhere the cord with the same input, and here you go! plug it into the pump at one end, another plug into 12V... Didnt have the cord with exactly the same input, so...
