01-23-2010, 09:10 PM | #1 |
Rep 361
Drives: '09 M3 AW Carbon roof DCT '11
To those with EUR fog light switch
With the switch off the both the inner and outer brake lights (in the fender) work but with the rear fogs on only the outer brake lights come on, at least on my car.
Anybody have the same? |
01-24-2010, 12:35 AM | #3 | |
Rep 361
The fogs are in the trunk lid. The brake light lights are in the fender. There are two brake light bulbs on each side in the fenders. When the fog light switch is in the off position all four brake light bulbs light up when the brake is applied. When the fog light switch is in the on position only the two outer brake light bulbs light when the brake is applied. I know the difference between the US and the Euro and how the brake force works. Again this is in my case. Last edited by Ctm309; 01-24-2010 at 07:21 PM.. |
01-24-2010, 07:54 PM | #4 |
Rep 40
Drives: 2009 M3 Coupe
Sorry to sort of thread jack, but I also have an 09 and have been looking for the fog light switch but have had no luck. Where did you get yours? When I do get it, then I can answer your question
2009 E92 JzB/FR/4MX:ZCW:ZPP:ZTP:752:655:6FL:415
3M 20%:3M clear mask:matte black front and side grilles:SilverVision rear turn signals:reflectors delete:Euro headlight switch, w/o front fog button:6000K LED Angel Eyes |
01-24-2010, 08:32 PM | #5 | |
Rep 5,012
01-25-2010, 04:45 AM | #6 |
Rep 361
01-25-2010, 05:34 AM | #7 | |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
I ended up spending $10 for some legos to modifiy the existing switch to make fog lights functional. Works perfect. I can't remember if the DIY came from this forum. I might be able to get a link later. Or do a search for legos. |
01-25-2010, 05:44 AM | #8 |
Rep 203
01-25-2010, 01:18 PM | #10 |
Rep 1,749
i just looked at this diy and took my oem switch apart. it has two white button plastic things in there even though its a us spec car? 2010 e90 October build.
03-09-2010, 02:25 PM | #11 |
Rep 40
This is how mine works too.
03-09-2010, 05:31 PM | #13 |
Rep 40
Turns on the rear fog lights.
03-09-2010, 07:34 PM | #14 |
8300
19
Rep 573
03-09-2010, 08:27 PM | #15 |
936
Rep 4,327
Drives: M340
And precisely for people like you, BMWNA does not offer them in the US. Most American's don't have a CLUE what they are..... :-)
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
03-09-2010, 08:37 PM | #16 | |
936
Rep 4,327
Drives: M340
Rear Fogs OFF w/ No Brakes: oo[oo ---- oo]oo Rear Fogs On w/ No Brakes: oo[OO ---- OO]oo Rear Fogs On w/ Brakes: OO[OO ---- OO]OO The only way all four bulbs should light up (when rear fogs are off) is during hard braking. If your car is doing this on regular basis, take it in have the dealer look at it. It is probably thinking that you are hard braking all the time..... It might be a bad sensor. Hope this helps..... Sorry about the poor graphics above
03-09-2010, 09:02 PM | #17 | |
Rep 6,125
Very creative way to explain the fog lights!
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
03-09-2010, 09:52 PM | #18 |
Rep 5,012
I think what OP said was there're TWO brake bulbs on each fender tail, with the fog one being the third. So when there's no fogs, both outer bulbs on each tail light up. And when fogs are on, only ONE bulb per side lights up, rather than all 3.
I haven't checked my car, but the fender tails seem too narrow to house 2 bulbs each IMO, but I could be wrong. At any rate, whatever it is, all M3s are going to do that since they're already prewired. Good evening. |
03-09-2010, 11:27 PM | #19 |
Rep 1,887
I'm not really sure what the OP is describing, but TTG got it right. That is how it is supposed to work; that is how mine work.
03-10-2010, 12:40 AM | #20 |
Rep 613
Uhh I know what a rear fog is, the question was why the euro switch is needed. Also an FYI bmw doesnt offer them because they arent a legal requirement in north america.
03-10-2010, 01:08 AM | #21 | |
Rep 1,887
The only difference between the switches is a small plastic tab that is removed from the NA switches which disables the fog light funtion. Put that plastic tab back in there and trim the plastic supports on the pushbutton and it works. The pushbutton face is also different... no symbol vs. a fog light symbol. There is a link previously in this thread if you want more details. |
03-10-2010, 08:36 AM | #22 | |
Rep 613
