02-08-2010, 06:09 PM | #1 |
60
Rep 970
Lutz Performance Presents N54 Active Autowerke Power Packages!
Hey guys, I know a lot of you are getting ready to use that hard earned tax return money on mods for your 1, and so we would like to give back to the 1 Addicts community and put together some specials for the guys interested in the Active Autowerke product.
Just some quick background info on Active, for those of you who don't know they have been in the BMW F/I market for well over 10 years, dating back to the E36 M3 turbo days, when they took the market by storm. Leading the industry in support, product quality and performance. We have been working with these guys for the better part of e years and I cant say enough about the effort Karl (AA Owner) and his staff puts into every product that leaves the AA facility. They know that BMW enthusiasts demand only the best quality product and they are ready and continue to set benchmarks in the industry. The current AA N54 products available for the community are as follows and I will after listing them all go through each product and explain in detail all features and give a package price at the end of this post. AA N54 Goods: AA 335 Short Shift Kit AA N54 BOV (blow off valve) Kit AA 335 Exhaust AA 135 Exhaust (comming soon) AA N54 Downpipes AA 135/335 Intercooler AA 135/335 Processor 2 AA 135/335 Methanol System AA 335 Short Shift Kit Key Features Modified carrier assembly Shifter creates up to 30% shorter throw Active Autowerke 8.25 oz Signature Knob All mounting hardware included Step-by-step installation instructions AA N54 Blow Off Valve Kit Key Features: High-efficiency single displacement BOV – takes place of two smaller plastic valves Large opening can handle maximum boost, provide high flow Proven and tested to handle 600+ HP All aluminum venturi design with factory-style throttle clamp CNC machined flange Durable black powder-coated wrinkle finish Illustrated instruction manual & installation guide for easy “Plug ‘n Play” 1 year limited warranty Video: AA 335 High Flow Stainless Cat Back Exhaust Key Features: Dual 90mm stainless steel tips Complete Bolt On (NO Cutting Required) Polished 100% 304 Stainless steel True X pipe Design Anti-Flex Design & Hardware All Stainless steel hardware Dyno-proven Gains 17+ RWHP Large inlet pipes with super high-flow design Illustrated instruction manual Videos: AA 135 Signature Exhaust Key Features: Full 304 stainless steel with hi-polish finish 3.50" size tubing with mandrel bends creates optimum flow NCC, noise cancellation chamber reduces noise and droan Dual 80mm Active Autowerke Signature tips mounted staggered Light weight Designed to use existing factory mounts and hardware Full adjustable mounting positions Easy and simple installation, just unpack and install Video: AA N54 (135/335) Performance Downpipes Key Features: An Active Autowerke Signature exhaust component Designed with less restrictive curves and more straight flows Full 3.00" diameter piping throughout creates the maximum in power output Quicker turbo spool, faster throttle response Durable construction from 304 stainless with 1.50mm wall thickness Precise fit installation Full down pipe exhaust support braces relieves load bearing stress Complete with DPP (Down Pipe Patch) Installation included with large pictures and short text Video: AA N54 (135/335) Intercooler Factory intercoolers work well on factory 135i’s, but with added boost comes added heat load. To overcome this, Active Autowerke’s unit stands tall and way up front, catching more air with the help an 88% larger core and a specially designed shroud. Our tests show an air temp drop of close to 30° F in the intake manifold, with a gain of 12 usable rear wheel HP on a Mustang MD250 dynamometer. btw: the ambient temperature in our shop measured a scorching 92°F during the session. This thing works. Dyno AA 135/335 Processor 2 Key Features Dyno measured increase in horspower of 80 HP and 80 Ft/Lbs gains Compact Size Unit makes it almost undetectable Eight (8) distinct tuned files pre-programmed within each AP-2 for easy access Easy tuned files selection program Full Control Over Fuel and Boost parameters and Ignition Reliable and compatible with latest BMW Factory software uploads Stabe boost increase delivery 4-D Mapping Technology Plug and Play Type Install Using Factory BMW Pins Unit Completely Reversible Easy to Install Performance Specs Power 71+ RWHP : (Stock Exhaust) Expect Higher gains when equipped with AA Exhaust and Intercooler upgrades Torque 85+ Ft Lbs of torque : (Stock Exhaust) Expect Higher gains when equipped with AA Exhaust and Intercooler upgrades 1/4 Mile: 11.9-12.9 : ( Depends on many different variables ) Dyno AA Methanol/Water Injection System Key Features Trunk-mounted 2.0 gallon reservoir with inline filter and low pickup tube Reservoir location on Battery Tray maximizes trunk storage Methanol-water mix is not influenced by either engine or exhaust heat Robust high volume pump will deliver on demand and is suited for a methanol-water mix Electronic module delivers precisely. Settings can be re-adjusted if needed Injection hose and wiring routed within a protective casing NOT a generic, universal system but manufactured model specific Detailed instruction with pictures makes for a simple install Tested and proven on our 500+ HP turbo and supercarged cars Email Parts@lutzperfauto.net for all specials for the AA N54 product!!! We are going to be offering specials for the power packages (including several AA N54 products in one package!) Last edited by Andrew@LutzPerformance; 02-09-2010 at 01:43 PM.. |
02-09-2010, 02:01 PM | #3 |
///Mmmm
78
Rep 796
Drives: '09 BMW 135i
Very nice selection here, Thanks for the compilation.
Current: E90 LCI 335i JetBlack - BMS OCC, JB4 w/ E85, ETS Charge Pipe, Vishnu Catted DP
Retired:///E82 135i LeMans - 12.710 @ 108 MPH Riss Racing OCC, Shadowline Grills, Magnaflow Axle-Back, JB4, ETS FMIC, BMS DCI, BMW Perf Sideskirts, BMS 12/10 Spacers, E93 Front Sway PDC Flickr YouTube |
02-09-2010, 02:17 PM | #4 |
60
Rep 970
No problem, I realized after talking with Jean last night that although there are many options, most of are scattered throughout myself and Ryan from active's posts. So I decided to make one big post with everything they have to offer!
03-12-2010, 11:54 AM | #10 |
60
Rep 970
03-12-2010, 12:36 PM | #11 |
Rep 64
Thanks for checking on this Laguna Seca has a 92db limit and they check it at one of the turns if you are too loud and can not fix it you go home. I have seen performace cars with stock exhaust that had to modify there exhaust to track at Laguna Seca.
