02-09-2010, 10:37 PM | #1 |
Rep 310
Request: VRS front lip installation guide
Hi guys, anyone here can share a VRS front lip installation guide (thru using self-taping screws and 3M tape)?photos & videos preferred....
very much appreciated.. |
02-09-2010, 11:01 PM | #2 |
Rep 319
I dont have any photos or videos but its not very difficult at all. I only used self tapping screws and its still on there tight after several days of hitting ice and slush from the MD winter we're having here.
I used a bunch of blue painter's tape to hold the lip to the bumper, tape it as tight as you can from under the bumper up to the top of the bumper/hood. With it in place I just started to screw it into the bumper. If you plan on using the 3m double sided tape, apply the tape to the contact area on the lip first then peel back a little bit of it before you do any of the steps above. when you secure it to the bumper with the painters tape just start to peel back the red backing little by little while adding pressure to ensure a good bond. |
02-09-2010, 11:15 PM | #3 | |
Rep 310
02-09-2010, 11:21 PM | #4 |
Rep 319
I put screws into all the screw holes. I think that will work, 3m tape when put on a clean surface is STRONG.
02-10-2010, 02:41 PM | #7 |
yodog
197
Rep 5,025
I just used screws alone, and it's held up very nicely with no gap at all.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
05-10-2010, 09:06 PM | #9 |
Rep 880
I have the vrs poly lip. On the middle section, there holes on the bottom strip yet there are no holes on the top part. Is that normal? Also do you have to drill through and put it into the bumper? The car is currently at the bodyshop and we aren't sure being that I got no instructions with the lip.
Thanks, Vin |
