03-01-2010, 12:18 PM | #1 |
Rep 2,502
BSH Ultimate N54 135i Recirculating Oil Catch Can!! {Redline Motorworks}
We are extremely proud and excited for the release of the BSH Ultimate N54 Recirculating Oil Catch Can.
This can will fit both the 135i and 335i. The BSH Competition Catch Can Kit is a completely bolt on and emissions compliant hardware package. This performance and longevity enhancing system connects together using in house manufactured billet adapters that simply clip into the existing connections found on the N54 engine. Blow-by gasses pass through these adapters into -10 oil and heat resistant lines and through the N54 specific BSH Competition Catch Can which has an important layer of aluminum mesh baffling to aid in the separation of oil and air. BSH simplified installation by designing a laser cut bracket and a new N54 specific catch can to fit perfectly giving a stock appearance. Installation and removal for draining is made simple by utilizing a drain plug mounted at the bottom of the can, and 2 easy to remove 4mm allen screws, allowing the can to come off and on in minutes. To check fluid level, BSH has added a billet dip stick for function without taking away from the form of the product by using an unsightly plastic viewing tube. This part is a direct addition to the factory PCV system and installs without any permanent or unsightly modifications to the vehicle. Includes: * BSH N54 Specific 3" Recirculating Catch Can * BSH Billet Dipstick * BSH Laser Cut Mounting Bracket * BSH outlet PCV adapter * BSH inlet PCV adapter * 10 Push Lock Line * All hardware needed for installation Retail: $259.99 YOUR PRICE: $229.99 with FREE SHIPPING to the lower 48 States Product Page: http://www.redline-motorworks.com/BS...p/10213100.htm How to order? You can order on our secure website by clicking on the respective links above. You can also call us at 647-827-0825 and order over the phone. We accept Visa, Mastercard and Paypal. Questions? 647-827-0825 info@redline-motorworks.com AIM: RedlineMotorwrks Last edited by RedlineMotorworks; 12-09-2010 at 08:25 PM.. |
03-10-2010, 06:55 PM | #13 | |
Rep 2,502
Any installation guide for a catch can will work though. I will try to put a rush on getting this DIY written up quickly. |
03-11-2010, 11:45 AM | #14 | |
Rep 1,477
1. If I can do it myself. 2. How good the product and vendor are going to be. Let us know when it is ready. |
03-11-2010, 03:52 PM | #16 | |
Rep 2,502
We've been carrying the BSH lineup since the very beginning. BSH stands behind their products 100% and offers incredible customer service before and after transactions. I personally have almost every part they've ever made installed on my GTI and the quality, fitment and performance gains exceed expectations. Sounds good. You'll really like this catch can setup. |
03-21-2010, 10:32 AM | #20 |
Rep 4,070
When will the instructions be up? I will order this once those are available....saw a good amount of oil in the stock FMIC....
03-24-2010, 04:09 PM | #22 |
Rep 2,502
Tags |
135 catch can, catch can, n54 catch can, oil can, oil catch can |
