03-07-2010, 10:00 PM | #1 |
Rep 604
Need Help Removing Fender Liner
Looking to remove the fender liner of the front driver side...any one have tips? I see a couple 9 or 10mm screws on the edge, but there are also the plastic plug things that I have no idea how to remove.
Anyone that has done it before...I dont need pics, but would like to know how much hardware needs to be removed to peel the section back directly in front of the tire. |
03-09-2010, 01:11 PM | #3 |
European Editor
10624
Rep 22,992
When ever I am contemtplating a repair or DYI, I tend to look at the parts films. Have you looked at Realoem?
Try this link: http://www.realoem.com/bmw/showparts...96&hg=41&fg=10 going on the parts diagram... it looks to me like there are: 8 x 8mm bolt screws 4 x screws 6 x expanding rivets Hope this helps you out. I don't think many people have R&R'd this inner fender pannel before. May I ask why are you doing so? Did you go plowing off road? |
03-09-2010, 04:52 PM | #4 | |
Rep 604
Thanks for the link, thats a great idea, never thought to look at the diagram and I even have the BMW TIS installed on my PC Any idea how to remove those expanding rivets? |
03-09-2010, 05:04 PM | #5 |
European Editor
10624
Rep 22,992
...... Well... hopefully we are talking about the #12 ones and not #13! lol Either way I would use some flat nibbler tool - used for cutting something flush. They are like small (electrical) side cutters(or dykes as some people call them) here is a link to the big German cousins of what I am refering too! http://www.autoschrauber.de/content/...zzange_nah.jpg I have a set of multi cutters & mini needle nose pliers. I think you could use something like them. IF its the flush kind of revits, you will need to use a pin tool or small nail to push fro behind the revit - to extend the center shaft - so you can get your needle nose pliers onto the shaft. You don't have to pull the shaft out all the way, just a bit so the fastener can come out. You might just order some of these revits so you are familar with working with them. They don't cost vert much. And most dealers SHOULD have them on hand. Should. take care, David |
03-09-2010, 05:09 PM | #6 |
Rep 604
hmmm...I thought I saw some of those 13s on fender liner near the brake duct hole (#14)...but maybe they aren't needed for removal and are just holding something to the back of the liner.
I only really need to remove part #6...or just even peel it back. Skipping the project for now Last edited by cadeucsb; 07-30-2017 at 11:08 PM.. |
03-09-2010, 05:23 PM | #7 |
European Editor
10624
Rep 22,992
Yea... I think only #6, (that lower front fendar linner) will need to be moved so you can see whats what.
Maybe after your done you will start to see why Bmw techs are getting the high hours they bill for doing a BmW Perf kit! lol I think that same fender linner must come out to cut a hole for the "extra mini radiator" that the kit comes with. I mean can it really take a tech four days to mount a radiator and cooling fan and relocate the horns? Ok ok! The kit is also software update and new spark plugs, but still!!! |
03-11-2010, 01:01 AM | #8 |
Rep 269
I removed both fender liners recently when installing my hidden meth system. It wasn't too difficult, but I definitley had to have the car raised since my front end is about 2 inches lower now on sport springs. Since we're practically neighbors as i recall, I'd be glad to show you how to pop those expanding plastic rivets on and off.
01-15-2017, 11:01 PM | #9 | |
Rep 382
01-16-2017, 10:28 PM | #10 |
708
Rep 3,268
Drives: 2010 128i
Use some trim removal tools to get under them and pop them out. If you don't have the proper tools, you could probably use the flat edge of a screwdriver or something, or even just tug on the adjacent part of the fender liner hard enough - the rivets will pop right out.
____________________________ |
