04-03-2010, 03:58 PM | #1 |
Rep 3,465
Drives: 997.2 GT3, '17 G30
Removing double-sided tape adhesive from clear-bra
My first real detailing question.
2 years ago, I mounted my euro plate over clear bra film on my front bumper using foam super-strength double sided tape. I was able to remove the plate from the bumper using a heat gun but did not ruin the clear bra application. I am left with a few strips of foam tape backing on my clear-bra'd bumper. Is there a good adhesive chemical remover I can use to remove it that won't take the clear-bra with the foam tape residue?
ig: 0verrev
04-03-2010, 04:10 PM | #2 |
European Editor
10624
Rep 22,992
This might be a good question for some of the detail experts on this forum. But I have always used 3M's General Purpose Adhesive Cleaner. Griots sells it.
http://common2.csnimages.com/lf/1/ha...ve+Cleaner.jpg bye, David |
04-03-2010, 05:26 PM | #3 | |
Rep 3,465
ig: 0verrev
04-03-2010, 06:43 PM | #4 |
European Editor
10624
Rep 22,992
I just looked at my BMW direction sheet for the clear bra.
It only says not to use a pressure washer near the bra film. For cleaning it says use a mild shampo (Johnsons & Johnsons baby stuff) and a plastic film polish for scratches. For removing the film it says to use a hair dryier/heat gun and some isoprobyl alcohol. It only says NOT to use gasoline - as that can age the film and harden it. Couldn't you use some goo-gone stuff? I don't know what else to tell you? bye, David Here is the BMW directions. Btw I still have not installed mine yet. |
