BMW M3 Forum (E90 E92)
BPM
      04-23-2010, 05:27 PM   #1
EAS
BimmerPost Supporting Vendor
EAS's Avatar
548
Drives: VF620 M3
▀▄ eas | DIY: Macht Schnell - Competition Stud Conversion Kit Installation
Step 1
Jack up the vehicle and secure it on jackstands.Unbolt the lug bolts.
Step 2
Remove wheel from hub.
Step 3
Remove wheel and clean hub of all dirt and/or surface rush with a wire wheel to ensure a clean and flush surface. [optional]
Step 4
Apply loctite onto the end of the studs and hand tighten the studs onto the hub.
Step 5
Use an allen wrench to completely tighten the studs onto the hub.
Step 6
Put your wheel back on and torque down the wheel locks. Repeat for the other three wheels.
This is how it will look finished without the wheel on it yet(also has a spacer on it)
Enjoy!
      04-23-2010, 10:42 PM   #2
SIIK2NR
South Korea
51
Drives: AW E92 M3
This is an awesome DIY. Answers many questions I had regarding. THANKS!
Current: 2006 Lotus Elise SC
Previous:
2008 AW E92 M3 6MT - Sold
2004 AP2 S2000 - Sold
      04-24-2010, 01:50 AM   #3
FruitCake
Taiwan
88
Drives: '10 E92 M3
no specific torque spec?
hmmm
      04-24-2010, 04:21 AM   #4
sehrgut
sehrgut's Avatar
33
Drives: emthree
Great info here, but whats the different by using new extended studs compared to buy extended lugbolts? thanks
      04-26-2010, 12:42 PM   #5
EAS
EAS's Avatar
548
Drives: VF620 M3
hmmm
The torque spec is the same as your lugs.
Many people prefer studs because of the ease of swapping wheels, and not having to change lugbolts every time they change wheels. Those would be the advantages of doing a conversion.
      04-26-2010, 10:42 PM   #6
LiM3y
LiM3y's Avatar
United Kingdom
70
Drives: 2008 E90 M3
I think he was asking the torque of the bolts in the wheel hub...although this is moot if they are stuck with Loctite?
      04-28-2010, 06:10 PM   #7
KM3
Formerly K335i
KM3's Avatar
19
Drives: 2009 E92 M3
Turner recommends 16 ft-lbs of torque for the stud in the hub. Nuts to stud should be the same as your original lug bolts (around 85 ft-lbs).
2009 E92 M3 :: Jet Black :: Fox Red Extended :: Carbon Leather :: 6MT :: JRZ RS Suspension :: RD Sport Sways :: StopTech Trophy Brakes :: Cantrell Brake Cooling
      04-29-2010, 06:01 AM   #8
LiM3y
LiM3y's Avatar
United Kingdom
70
Drives: 2008 E90 M3
      05-04-2010, 12:24 PM   #9
Alex///M
E90 - the Ultimate family hauler
Alex///M's Avatar
Drives: 2008 E90 ///M3
How much is a kit like this? Considering the amount of times per year I swap wheels for track and street duty this might be a great mod.
2008 AW E90 M3 - current
2002 TIAG E46 M3 - gone
1991 DiamondSchwartz E30 M3 - gone but not forgotten
      05-04-2010, 12:37 PM   #10
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Everything can be found on our website.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      07-23-2011, 07:57 AM   #11
Stormtroooper
The General
Stormtroooper's Avatar
34
Drives: 2018 M3CS
2011.5 M3  [10.00]
Thanks for the write up David. Been looking for this.
E92 M3
2011.5 AW / DCT / ZCV / ZP2 / Heated Seats (SOLD)
2018 M3CS
      12-31-2011, 11:55 PM   #12
Definitive
definitivecars.com
Definitive's Avatar
Drives: Elsa - 2015 F80 M3 - YMB/SS
Question, Can you get these off later, Like 1.5 years later for lease return?
D
      01-03-2012, 02:14 PM   #13
EAS
EAS's Avatar
548
Drives: VF620 M3
D
Yes you sure can, they come off as easily as they are installed!
      01-03-2012, 04:07 PM   #14
Definitive
definitivecars.com
Definitive's Avatar
Good to know thanks.
      05-09-2012, 09:49 PM   #15
adc
Drives: 2018 F80 M3 ED
Can someone please explain why 16 torques is sufficient, when the lugs will need 85? Won't the studs come off when you try to remove the wheel?
Does the loctite hold it together? I mean, the hub can take 85 and more...
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      05-11-2012, 12:40 PM   #16
EAS
EAS's Avatar
548
Drives: VF620 M3
The stud torque is just to keep it on the hub when you loosen the lugs. The 88 ft lb. on the lug nut will determine the actual torque of the stud and nut.
      10-30-2012, 03:58 PM   #17
sterile stork
coupe la goon
sterile stork's Avatar
Drives: green, black, white
Good lord, imageshack as an image host, and in a vendor DIY? Unimpressive.
m3post
