05-19-2010, 06:17 AM | #6 | |
e36s54, e70x5d
151
Rep 1,723
and +1 for OE 8" mid-bass = if you feed a clean signal to these, you will be surprised. |
05-19-2010, 10:00 AM | #7 |
Rep 807
Audio installer put I'm a audison bitone, morel hybrid ovation, focal k2 power all running on a jl audio HD600/4 he also installed a Rockford fosgate t1000 and kicker l7 meanwhile until I find a replacement for under the seats. He advices me to go with the morel 6" 3 way components now with that set up dynaudio or any of the others mentioned a good replacement? Thanks
05-19-2010, 11:06 AM | #8 |
8 tracks of madness
62
Rep 2,735
05-19-2010, 11:09 AM | #9 | |
8 tracks of madness
62
Rep 2,735
05-19-2010, 05:31 PM | #11 |
Rep 807
also whats the difference between Esotar 430 and MW172... which would go under the seats if I go that way? Which amp would be best to run with my current set up
05-20-2010, 07:38 AM | #13 |
BMWCCA Member
Rep 51
Drives: '11 AW ZCP ZTP E92, '21 X5 M50
The Dynaudio 172 shows a mounting depth of 78mm to the Morel 71mm, and the Morels that have been shown installed here by VP Electricity have had the enclosures ground down and are mounted with a (3/4"?) spacer that brings the speaker right up against the seat rail. I'm not sure how you would install something deeper without alot of modification.
05-20-2010, 08:04 AM | #14 |
8 tracks of madness
62
Rep 2,735
The grill on the Morel hits, not the driver. The driver is under the seat. Unless you plan on chucking stuff under there you'll be fine without a grill. If you want a grill, go with the
Morel. |
05-20-2010, 07:29 PM | #15 |
Rep 807
thanks for the help man i'll run it past my installer... also what amp is best to run those 2 under the seat and i guess a rear L7? all with audison bitone and the other amp is a hd 600/4
05-21-2010, 02:08 AM | #16 |
8 tracks of madness
62
Rep 2,735
I like to match so I'd run another 600/4 and a 750/1. You could always check everything and use Audison amps with the link between the B1 and the amps. Pretty sweet. I almost did that myself but ended up selling the B1 and ordered a JBL MS-8.
05-21-2010, 07:27 AM | #17 |
Rep 807
nice so basically run (2) jl audio 600/4 and (1) 750/1... the 750 I imagine would go to the L7? and the other 600/4 would run the midbass? or is that too much power?
05-21-2010, 02:45 PM | #19 |
Rep 3,969
Have you actually confirmed this? You know, the basket on the MW172 is a hell of a lot wider than the Morel's, which means even at identical mounting depth, the Dyne would sit higher than the Morel, due to the slanted enclosure bottom.
05-22-2010, 04:00 AM | #20 |
8 tracks of madness
62
Rep 2,735
Talk to Ken (VP Electricity). He's done the Morel on a few cars (1 and 3ers) and it's confirmed.
Have you looked at the basket on a Morel? Morel has been using a Dyn style basket since they were nothing more than a Dyn ripoff back in the day. The Elate and Supremo 9" basket is almost exactly the same as the Dyn and is quite wide itself. Fitment of either shouldn't be terribly difficult. |
