05-16-2010, 01:58 PM | #1 |
Rep 38
Drives: 2010 M3
Hood out of alignment
My hood appears to be slightly off alignment with the driver's side being maybe 5mm back when compared to the pass side. You can see a bit more of the front bumper on the drv side from above. Its not a big deal but a bit annoying and I'd expect a tighter fit on this car. Anyone else seen this issue and is there an adjustment I can do or should I just let the dealer fix it?
Thanks
2010 E90 ///M3 : /SG/M-DCT/19" HRE P40s w/Yokohama AD08s/Vorsteiner CF Aero fr lip and rear splitter/Akra Evolution w/ akra ESS tune/Macht Schnell CAI/CF Grills & Gilles/Prem pkg/tech pkg/Nav/mnrf 2006 Z06 |
05-16-2010, 02:46 PM | #2 |
Rep 513
Take it to the dealer. It might just be a byproduct for the vertical adjustment being off. Have you read the threads about a hood not seating flush on one side or the other? You can tweak the rubber bumpers a bit to adjust the vertical seating. This may or may not be helpful to you. In any event, I'd bet the hood is fitted to the car, which hopefully means it can be refitted. Good luck.
05-16-2010, 06:28 PM | #3 |
Rep 3,941
I have yet to see a E9* M3 that had a properly fitted hood all around. They all seem to have alignment issues with the fenders and/or front end. I guess BMW has many folks who make these adjustments on the assembly line in need of a vision exam for corrective lenses.
I hope a dealer can help with the alignment. On my car the fender to hood gap gets larger the more you look at it from the front to the rear where it meets the door. |
05-17-2010, 10:46 AM | #4 | |
Rep 754
2011 E90 M3 Alpine White M-DCT
2011 E92 M3 Individual Dakar 6MT |
05-17-2010, 11:04 AM | #5 |
Ultimate Driver for the Ultimate Driving Machine
146
Rep 1,146
I havent heard of alignment issues but many "not closing evenly" issues
BMW M3 E92 - Silverstone II BPM Sport Stage II Tune + Test Pipes, GTS DCT Tune |
05-17-2010, 11:05 AM | #6 |
Rep 754
My 2011 E92 M3 is on the Ship…
Question, is there any way to get an M3 with a perfectly aligned hood. Also, if it comes in not aligned is there anything they can do about it? I don’t see how they can possibly move the hood back in order to line it up. My other 2009 BMW is aligned perfectly.
05-17-2010, 02:09 PM | #7 |
NASA SpecE30 Racer
82
Rep 1,307
The hood is adjustable just like the hood on any other car. I know when I got mine I had to make some adjustments to the rubber hood stops to get the front edges of the hood to line up with the fender.
King Tut
2012 BMW M3 Individual: Sold lsb.ridedomain.com 1987 BMW 325is SpecE30: spece30.ridedomain.com 2009 BMW M3 Coupe: Sold e92.ridedomain.com |
05-17-2010, 02:52 PM | #8 | |
Rep 754
That is exactly what it was, the hood was not aligned with the bumper, and it was about ¼ inch or so past where the bumper meets.
05-18-2010, 12:18 PM | #9 |
Rep 38
Drives: 2010 M3
Thanks for the replies. I had seen the posts on the closing issues and on adjusting the rubber stops. I looked at the hood and front end more closely and found that the front bumper alignment moves quite a bit with adjustment of the four torx screws in the front. In fact, I had changed out my grill for CF and didnt realize how much play was in the bumper. So I loosened things up a bit and retightened while putting forward pressure on the rubber bumper. Now the front is nicely aligned. Looking at the back of the hood by the windshield, there is a tiny variance in the gap with the fender comparing both sides but its minimal (1-2mm). I'll control my OCD now ..LOL. I need to remember that you cant compare car building to brain surgery where 1mm-2mm off counts. Anyway, I love the car...
05-19-2010, 01:29 PM | #10 |
Rep 106
Same here, there is more gap between the fender and hood on the driver side when compared to passenger side. Even I checked it with digital calipers.
05-19-2010, 05:44 PM | #11 | |
Rep 3,941
But at least I know my car isn't the only one with misaligned hood/fenders. |
05-19-2010, 11:32 PM | #12 |
Rep 4,903
Drives: '08 E92 M3
Mine do not line up correctly either, I just ignore it though.
'08 E92 ///M3 - AW/BLK/CF, M-DCT, 19's
H&R, Vorsteiner, Eisenmann, BMC, BBS More to come... |
05-19-2010, 11:52 PM | #13 |
Rep 754
You can count on me checking out my new M3 before taking delivery.
What do you do if it doesn’t align, just accept it?
2011 E92 M3 Individual Dakar 6MT Last edited by Mr C; 05-20-2010 at 12:21 AM.. |
05-20-2010, 01:53 AM | #14 |
Rep 4,903
Drives: '08 E92 M3
You could always ask them to adjust it.
05-20-2010, 09:25 AM | #15 |
146
Rep 1,146
Or you can let the gap stay there, once you hit the gas the engine compartment will need every bit of extra air to cool down
05-20-2010, 10:24 AM | #16 |
Rep 210
Mine didn't line up correctly either, it can be adjusted. The guys at the Performance Center fixed it for me (more on that later) and were perfectionists about it.
05-20-2010, 02:16 PM | #17 |
Rep 1,570
Drives: 2013 LRP M3 Coupe
seems like a common problem.. my stock hood wasn't 100% perfectly aligned either.. seemed slightly off in front.. but not horrible to the point that it bothered me.
02-21-2011, 03:54 AM | #18 |
CLU KINGSMEN
29
Rep 566
Just thought I'd add to this.....since I was just doing research on this issue because my 2011 E92 had the same exact issue!!
I went down to the garage & checked, popped the hood open....and...lo and behold...the right bumper plug was was looser and "higher" than the bumper plug on the left!! I had the same issues as someone here who posted that their hood had a slightly larger gap on the driver side (FROM the perspective of one who would be/were standing in front of their car)after being closed I tightened the "higher" bumper plug down and it shut easier and all is aligned.
E92 M3 Satin Black GTS ModeCarbon Rimier MotorSports Premier Protective Films
HRE || RECARO || KW |
02-21-2011, 11:18 AM | #19 |
Rep 1,153
My dad noticed this last time we were at the dealer. He looked at the hood of every M3 on the lot and not a single one had a hood that aligned properly. The should be embarrassed to have an issue like this - it's not a cheap car!
02-21-2011, 11:20 AM | #20 |
Rep 7,594
Drives: '19 M2C
I've had to slightly re-align hoods and/or trunks on the last 3 BMW's I have owned.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
02-21-2011, 11:33 AM | #21 |
Rep 7,594
Drives: '19 M2C
I'm going to get flamed, but two BMW's a '98 Z3 and '00 M Roadster I had we're both perfect.
Hey Germany whatcha doing? - Both of these cars we're built in Spartanburg, SC USA
02-21-2011, 11:52 AM | #22 |
Rep 543
After reading this thread I'm afraid to go into the garage. I know the first thing that I'll do is check the hood alignment and if it's off..............
