BMW M3 Forum (E90 E92)
Mporium BMW
      06-06-2010, 03:39 AM   #1
bavarian06
bavarian06's Avatar
74
Drives: e46 m3
How to remove front seat cushion?
Has anyone done this? I want to swap out my driver seat cushion for the passenger seat cushion. The driver seat has a deep crease that is getting worse as I sit on it.
I want to swap it to give it some time to reshape. I've used leather conditioner to treat the cushion but it isn't helping so hence this idea.
Thx in advance!
      06-22-2010, 09:51 AM   #2
3XTR3M3
3XTR3M3's Avatar
Drives: E92 AW M3 6MT
not a bad idea. Ive had mine since March 2008 and am feeling the same.
      06-22-2010, 07:35 PM   #3
sl0westz
Drives: AW e92 m3 ess vt1. AW F10 m5
in order for you to take out the seatcushion, you have to take out the back support 1st. but its not possible to swap driver to passenger side because passenger side uses oc3 mats, and will trigger airbag light on. i have done this before by accident (put passenger on driver not knowing, after putting everything back together, airbag light will stay on and have faults for seat occupancy detection.came to find out, the driver seat had the passenger seatmat on) so the only thing you can do is buy replacement leather piece for your driver seat, remove the seat cushion, the leather is held by about 20 hugrings on to the actual cushion foams.. you have to cut them out and put the new leather on with new hugrings
      06-23-2010, 12:34 AM   #4
bavarian06
bavarian06's Avatar
74
Drives: e46 m3
thats bad news. i wonder if i can take it to my dealer and claim it under premature wear. my car has 12K miles, i wonder what the seats will look like in 50K.
      01-17-2014, 03:50 PM   #5
gazosnic
Drives: bmw m3
anyone every try this... i was thinking about adding more foam for the drivers seat or buying the replacement lower cushion from bmw.
      03-03-2014, 07:14 AM   #6
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
I'll ask the obvious question -- is it impossible to swap the airbag occupancy sensor mats?
      03-03-2014, 12:26 PM   #7
s85e90
Drives: black e90
no and they sell the mat separate which is handy if you want to retrofit some buckets to have it work as advertised.
You do need to take the cushion apart though
m3post
