06-07-2010, 03:19 PM | #1 |
Rep 313
Correct Brake Bleeding Sequence?
I did a few searches and people seem to suggest that the following is the correct sequence in which to bleed brakes:
1. Passenger's rear; 2. Driver's rear; 3. Passenger's front; and 4. Driver's front. Can anybody confirm whether or not this is correct? Thanks in advance. |
06-07-2010, 04:03 PM | #2 |
One mod leads to another ...
419
Rep 2,900
That is what I have always heard. Farthest away from the master cylinder first and then work your way to the closest caliper and do that one last.
Current: 2014 F10 M5 Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3 |
06-07-2010, 07:12 PM | #4 |
Rep 5,012
It happens to be correct for the M3, but not always. You want to start with the longest line from the ABS/DSC MODULE. Some cars have it on the passenger side, so the correct sequence there would be RL, RR, FL, and FR. On the M3 is right by the brake booster, so your sequence is correct. And if you do the bleeding regularly, it doesn't really matter. Take care.
