08-01-2010, 12:35 PM | #1 |
Rep 961
Anyone heard of PCCB problems recently?
This isn't a "bash Porsche" thread, and it might not even be in the right section, but I want to tap into the collective consciousness on PCCB brakes and how they've been standing up lately. If you track your M3, you spend a lot of time hanging out with Porsche drivers.
I've done two track days in the last three weeks, and one of the participants at both is a gentleman who, depending on how he's feeling about things on the day, turns up in either his CGT or his 2010 GT3RS. The CGT is his favored track car, although he's been using his GT3RS a lot lately. That's because the CGT is sidelined to replace the brake rotors and it takes a while to get them from Germany. It came with PCCB but he's replacing them with cast iron. The car, as I understand it, has about 10,000 virtually all-track miles, so the PCCB's have done well. The lovely new (and it's gorgeous) GT3RS has already been switched from its original PCCB's to cast iron. I don't know exactly when it was delivered, but it's probably only three months old or so, so it's very recent production. I'd seen the car a month or so back with the PCCB's on it, and when I saw it two weeks ago with cast iron rotors I asked the owner what was up. He said the PCCB's lasted three track days and that was it; the rotors were worn out and had to be replaced. Porsche told him that PCCB rotors have been re-engineered recently, and that's why his GT3 brakes wore out so fast. Given Porsche's vast capabilities in making brakes for sports applications, it sounds very odd that they would re-engineer their top-tier product and have it turn out worse than the "regular" stuff. Has anyone else heard of anything like this? |
08-01-2010, 01:26 PM | #2 |
Rep 1,084
Drives: 2009 E-90 M3 space gray
Location: Deutschland KreisTrier auf Autobahn 64 & Tucson AZ
I use to think PCCB where the shit! Sport Auto fielded a totally Stock GT3 RS at this years Nurburgring 24hr race. When they prepped the car they removed the stock wheels the PCCB and added the front roll cage and removed passenger seat and installed full FIA certified race seat. To tell you the truth I don't know if ceramic brakes are illegal for VLN or Nurburg 24 hr race or there not just durable enough? I had a porsche friend take his Boxter S through the gravel trap at a local track and it broke his ceramic rotor and it was big $$$$
08-01-2010, 01:33 PM | #3 |
Moderator
675
Rep 4,737
From what I've read on the subject, to properly utilize PCCB rotors on the track you will need to get special Porsche pads. If you use the stock pads, the PCCB rotors will be ruined pretty quickly.
08-01-2010, 05:09 PM | #4 | |
Rep 9,034
Porsche has two brake pads for their PCCB rotors. Both are thought to be Pagid's, but I'm not sure which ones. They come with the street pads and you need to get the track pads if you're going to track. You can't use the street pads on the track or you'll destroy the rotors. You can use the track pads on the street with obvious limitations in cold braking. You can quickly destroy the rotors if you use other pads, particularly on the track. People have had multiple track days with the PCCB while using the proper pads. Some people even say it's a wash compared to iron rotors, particularly if you're having someone else change them out. The first gen PCCB did suck and failed pretty easily, but the newer ones are suppose to hold up well as long as you use the right pads.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
08-01-2010, 05:51 PM | #5 | |
Rep 961
08-01-2010, 07:01 PM | #6 |
Rep 1,787
I have a 2010 Gt3 with PCCB. I run Porsche Motorsport P50 "Greens"...
This is THE ONLY, let me say again THE ONLY pad designed for the PCCB. This pad is made by Pagid for Porsche Motorsport. It all comes down to what you have heard. Plenty of people run PCCB and have years on them, literally. You need to do a few things to be certain they last... a) Proper cool down after sessions b) Run with the gizmos off as this kills the rear pads/rotors when traction control kicks in c) Proper pads and proper pad life! Most people swap out pads with 40-50% left to be sure nothing happens Running the "P50 Greens" with PCCB has been great - plenty of bite when they heat up. Again, make sure you really heat them up or you are in for a ride come the first turn! |
08-01-2010, 07:33 PM | #7 | |
Rep 3,832
08-02-2010, 01:19 AM | #11 |
Rep 9,034
This Champion???
08-02-2010, 01:21 PM | #13 |
Rep 1,787
08-02-2010, 04:46 PM | #14 |
Rep 9,034
Please post pic's when you get your car back!!
08-07-2010, 05:00 PM | #16 |
Rep 9,034
Bump for pics? If you even get out of the car!!
08-08-2010, 06:34 PM | #17 |
Rep 1,787
Car will be done this week - I will update then
Front RSS Mono ball kit with rear lower Control arms with RSS Thrust Bushing and Monoball A-Arm Kit. RSS Adjustable Upper Rear links RSS Competition Roll Bar ( Buttoning up some of the finishing touches ) Colored Protective Film for the Front Headlights and Fogs/ LEDS |
08-09-2010, 10:17 AM | #18 | |
Moderator
96
Rep 1,920
I don't think they disliked the PCCB's of thought there was a longevity issue with them (I never heard a complaint other than cost). However, being as Porsche has redisigned them, I guess it's possible they are making them a bit more robust? I dunno, but I never heard a complaint from the guys I used to run with.
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
08-11-2010, 09:57 AM | #19 | |
Rep 961
08-11-2010, 10:38 PM | #20 |
Rep 9,034
Martin's car is SICK!!!! Pic's on 6-speed.
I'll let him post where ever he feels is appropriate. And I'm pretty sure the cars with PCCB include instructiosn not to use the street pads on the track and they can ONLY use the Porsche track pad at the track.
08-11-2010, 10:59 PM | #21 |
Rep 3,832
His car is stunning!!!
08-12-2010, 01:37 AM | #22 |
Rep 3,157
freakin sick cars
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
