08-01-2010, 02:52 PM | #1 |
Rep 441
Drives: 1M
2008 Ash Tray to Cubby Help
Is it possible to eliminate my ash tray and swap it for a cubby assembly? I have no need for an ash tray and would like to have additional space for my glasses and such. If it is possible, does anyone know the part number I would need to order. Thanks!
08-01-2010, 03:29 PM | #2 |
Rep 1,410
Drives: X3 M40i
interested in this too
08-01-2010, 04:24 PM | #3 |
Rep 536
Yes you can. You need to remove the center console (see my DIY thread) in order to remove the ashtray and install the cubby.
edit, just saw you are in Cincinnati. I can help you if you get stuck. I even have a spare cubby if you have not bought one. |
08-01-2010, 05:52 PM | #4 |
Rep 3,547
The shallow part of the door pocket works well for my sunglass case.
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
08-01-2010, 06:38 PM | #5 |
Rep 2,431
Easy swap out. Takes all of 10 minutes or so. Hardest part is disconnecting and reconnecting the wires under the center console. Mine had steptronic and iDrive so there were three connectors to disconnect. IDrive, Selector and lighter wires. Reconnection was of course just iDrive and selector wires. There's even a mod DIY to use the leds from the ash teay to light the cubby. I didn't do that but it was pretty cool.
08-01-2010, 10:07 PM | #6 | |
Rep 536
08-02-2010, 07:22 AM | #7 |
Rep 441
Drives: 1M
09-14-2010, 08:04 PM | #8 |
Rep 193
My 2011 has the cubby I would like install the ashtray instead. Can someone point me toward the part numbers for the ashtray and diy instructions?
btw I don't smoke cigs, so if your gonna tell me how bad smoking is, save it please. |
09-15-2010, 07:12 AM | #9 | |
Rep 536
You can look up part numbers at RealOEM You can find my DIY on removing the center console through a search. |
09-17-2010, 10:57 PM | #10 |
Chirurgeon
39
Rep 424
Struggling to find the cubby assembly on realOEM, would love to be rid of ashtray also! Some help would be appreciated - like the proper name for it or perhaps even part number anyone?
cheers
E Pluribus Unum
10-18-2010, 04:45 AM | #11 |
Rep 1,375
10-18-2010, 08:01 AM | #12 |
satch
39
Rep 1,040
04 Utility box, front 1 51167136190 $15.34
05 Rubber insert, oddments tray 1 51167154854 $7.52
"The Dingo ate your Mustang" |
10-18-2010, 01:36 PM | #13 |
Rep 567
FWIW, when I did this mod I ordered both of these part numbers as well. However, the cubby itself comes with a rubber insert of its own, so I ended up with two inserts. I'm not sure if that is intended or not, just thought I'd share.
10-18-2010, 06:24 PM | #14 |
Rep 2,229
+1 I was just gonna say the same thing, my cubby came with a rubber insert already so there's no need to order one.
10-21-2010, 08:06 AM | #15 | |
Digital Cerebrum
18
Rep 408
Drives: 05 330ci ZHP
direct to center console - http://www.realoem.com/bmw/partgrp.d...22&hg=51&fg=35 |
