08-03-2010, 12:53 AM | #1 |
Rep 6,107
RD Sport Sway bars installed
I recently swapped stock sway bars with RD Sport kit.
Good: You can feel the difference right away. The car feels stiffer and the body-roll is definitely reduced. Both front and rear bars are much thicker than the stock bars and can be adjusted within a few minutes right at the track. Bad: The installation process is PITA. It take a out 4-5h to replace it if you know what you are doing. I should probably say it takes about 30min to replace the front bar, and around 4h to replace the rear. Overall I am very happy with the product and the results and can't wait to take it to the real world testing "track" This is something I would definitely recommend doing if you are looking to reduce body-roll. I will post a few pictures soon ... |
08-03-2010, 01:35 AM | #2 |
Dog Listener
707
Rep 7,850
Cool! You have to drop the rear sub-frame to do the rear install right? That lift you have sure comes in handy for something like that; no way I'd do that with the car on jacks!
08-03-2010, 01:41 AM | #3 |
439
Rep 2,373
08-03-2010, 03:03 AM | #4 | |
Rep 2,991
doba_s - how is the ride quality? Feel anything different? When I put sway bars on my E36, the ride quality took a nose dive, because they tended to bind a bit during the travel making it rougher. I left sway bars off the my E46. |
08-03-2010, 02:41 PM | #5 |
Dog Listener
707
Rep 7,850
Well, let's just say I'm not going to try it! Small stuff, yeah, major work like this...nope. I might be up for trying it if I had a lift; otherwise like Aleks says it's a week in the driveway and problem never ending shoulder pain from that point on....
08-03-2010, 06:47 PM | #6 | |
Rep 2,266
Cheers
Ben |
08-04-2010, 01:33 AM | #7 | |
439
Rep 2,373
08-04-2010, 11:07 AM | #8 |
Rep 2,991
hehe don't get me wrong, I'd pay someone too.
08-04-2010, 11:19 AM | #9 | |
Rep 2,266
Again, I'm not sure if it's a placebo ..but every time I get sways done it feels like the ride gets a tad bit harsher...same Hotchkis on my old car.. It's really not significant enough to be a factor in not buying this for sure.
Cheers
Ben |
08-04-2010, 07:45 PM | #10 |
Moderator
675
Rep 4,737
It is possible that the ride may be stiffer.
Sway bars basically connect the left wheel to the right wheel so that in a corner one wheel can "borrow" stiffness from the other to reduce body roll. Therefore, in a situation (i.e. going over a bump) when there is a big difference in wheel position between left and right, you may actually feel the additional stiffness. |
08-07-2010, 07:33 PM | #11 |
BimmerPost Supporting Vendor
732
Rep 3,735
An inherent property of stiffer sway bars is a more uncomfortable ride.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
08-07-2010, 11:57 PM | #12 |
Rep 566
08-08-2010, 05:08 PM | #13 |
yodog
197
Rep 5,025
+1. Going to stiffer springs, even Eibachs are more noticeable in terms of comfort than upgrading your sway bars.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
06-18-2012, 08:38 AM | #15 |
Rep 1,286
I'm curious too. I was interested in doing this but when I spoke to the Ground Control folks they told me they had installed three sets of front and rear bars on E9x M3s and removed two sets because the owner's didn't like them.
There's no doubt that roll is reduced but the question is, is cornering performance improved? When you look at the stock M3 bars they are pretty massive stock (at least compared to all the other bars I've seen on other cars). |
06-18-2012, 11:13 AM | #16 | |
Rep 3,832
06-18-2012, 04:28 PM | #17 |
Rep 1,286
That they stiffened up the suspension more than they expected and that they were less compliant over bumps. Net was that it wasn't clear that it improved anything.
I think it now that there is some M3 race car experience it would be interesting to see what Turner or other race teams are using for anti-roll bars and whether they find that an even larger diameter bar is needed. Not obviously the same as street but if they're not doing it, perhaps we shouldn't be either. |
06-19-2012, 01:10 PM | #19 |
Rep 1,624
We are running the H&R sways front and rear but have not had time to compare them to stock. So far the car feels good after the first race but we are going out for some testing in the next few weeks to sort the car. But this is a full time race car so comforts on the street i'm not sure we can help yet.
