08-20-2010, 07:40 PM | #1 |
Moderator
675
Rep 4,737
The M3 GTS BMW Should Have Built.
I bet many are quite disappointed with GTS's 7:48 'ring time. The fact that the GTS is slower around Hockenheim than the a-workx M3 - a car that basically has bolt-on mods (KW CS, Akrapovic Evo, PSCup) - is simply embarrassing.
I am no M engineer but have certainly played with this car for many years. Here's my 2 cents to make a 7:40 GTS. 4.6L Stoker Engine: 500 hp Dinan can do it and offer a warranty, why can't BMW? GTS's S65B44 is only 30hp more than the S65B40, a gain attainable with just race cats and a tune on the stock engine. The Nurburgring has many long straights and the GTS can certainly use more power. Carbon Fiber Doors and Plastic Rear/Side Windows All these parts are readily available from the M3 GT4. They can easily cut another 100+ lb (Ericsson's CF doors alone cut 67 lbs). Wider Wheels and Tires The only thing between you and the road are your tires. For a relatively heavy car you need more rubber. Most people on this forum easily squeeze 9.5" width w/ 265 tires up front, and 10.5" width w/ 295/305 tires in the back. How about 18" wheels and cut another few pounds? And forget about the fancy PZero Corsa. Michelin Cups are plenty! The Result: 500 hp, 3400 lb (GTS: 3538) More power, less weight, and wider rubber. These readily available modifications and parts can easily propel the GTS into the 7:40 territory... with just a bit more of investment. Your thoughts? |
08-20-2010, 07:44 PM | #2 |
Rep 2,091
For the price I would much rather buy a Porsche GT3 over a M3 GTS, this coming from someone that has owned 3 M3's (one currently) and a 997 C2S.
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia 2020 BMW X7| Mineral White 2024 718 GT4 RS | Arctic Grey |
08-20-2010, 08:00 PM | #4 |
Moderator
675
Rep 4,737
Guys, I am not asking which car has better value.
I am talking about how BMW should have designed the GTS with nearly the same amount of investment to live up to its targeted class. |
08-20-2010, 08:02 PM | #5 |
I like cars
331
Rep 5,052
I think they should have gone with something closer to the CSL.
Remove back seats, go with light front seats (with an OEM look), carbon fiber door panels, reduced sound deadening, slightly more power, etc. Make it smooth and factory like, rather than tacked on looking like the GTS is. |
08-20-2010, 08:05 PM | #6 |
Rep 1,033
Yea for the money you shell out for a GTS I'd say that the list you had makes way more sense. 4.4L is not much of a step for all that extra work and effort. But hands down, who wouldn't want a GTS as it is now?
08-20-2010, 09:05 PM | #9 |
Rep 77
I absolutely agree. For the money GTS owners have paid, there should be way more performance being squeezed out of that thing. After all, it is car meant for the track, I'm sure there could be a lot more weight savings. And it could use a bit more power.
08-20-2010, 10:42 PM | #10 |
Rep 843
I just don't see the point of this car. You're starting with a sedan/coupe architecture that has weight built into it that you're really not going to get rid of. While it would cost a lot more to develop, I feel BMW would have been better served to have made a lightweight, mid enigned car, using the S65, as a halo car for BMW and to highlight this gem of an engine.
08-21-2010, 04:39 AM | #11 |
yodog
197
Rep 5,025
I'm with you rldzhao. The whole car doesn't make sense but your description is how they should have built it. A bolt on regular 4.0L M3 beating the GTS is very embarrassing. They should have SC'd the damn thing!
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
08-21-2010, 05:40 AM | #12 |
Rep 17,493
Drives: like I'M BOUT THAT LIFE
couldn't agree with you more, op, but i still want one. imo if you can afford to own a gts you can definitely afford to make it lighter, install a supercharger (i know that's besides the point) and call it a day. case closed.
btw, no matter what bmw builds people will buy... aren't all the gts' allocated?
#datbimmerdoe #thatbimmertho
FOLLOW @datbimmerdoe on INSTAGRAM |
08-21-2010, 06:02 AM | #13 |
Just call me J.J. McClure
156
Rep 2,834
Spot on, rldzhao. The GTS should have BMW's "show off" car, instead it's proof that they simply rushed the product to market to compete against cars like the GT3 RS. A big "FAIL" for BMW in my opinion. GT3 RS is still king!
MODS: Meisterschaft GT Racing Exhaust / BMC Air Filter / UUC SSK & DSSR (Modded)/ RPI Scoops / Passport SRX Hardwired / Custom Wrap 3M Clearbra / 20% Tint / 50% Windshield Tint / Key Hole Delete / Matted Out Accessories / VRS Type II Diffuser / Smoked Reflectors / Euphoria 6K LED Interior Lights / Rear Fog Light Mod / 6000K HID's / 6500K LUX H8 Angel Eyes / RDash License Plate LED Kit / LED Xenon Reverse Lights
"M3 drivers have no friends" |
08-21-2010, 06:05 AM | #14 |
Rep 1,084
Drives: 2009 E-90 M3 space gray
Location: Deutschland KreisTrier auf Autobahn 64 & Tucson AZ
Most definitely GT3 is way better value for performance. Plus i'm no fan of everyone haveing the same exact color Lame!
08-21-2010, 08:04 AM | #15 |
Moderator
7525
Rep 19,368
I think you nailed it. The 4.4L stroker is great and all, but it probably ate up a ton of the R&D budget for the car and simply did not pay off. Others have done it with much better results. And, yes, the lack of a better weight loss program for the car was one thing that surprised me from the beginning. Overall they needed to bring a lot more of the GT4 to the production car.
BTW, how much is a GT4? And what would its ring time be? I know its not street legal, but it probably could be with a different exhaust. |
08-21-2010, 08:26 AM | #16 |
Rep 157
M3 GTS was built as a Street Legal race/track car.
For only track/race use we have GT4. But as of M3 GTS , i believe it is an utter fail . Too much money for nothing. Those "mods" are worth not more than 10k Euros ,and they ask 5 times more for it than stock M3 (Euro prices) I'd still say , get M3 , get it race prepped for 30k $ and beat the crap out of GTS.. |
08-21-2010, 11:58 AM | #17 | |
Moderator
675
Rep 4,737
08-21-2010, 12:07 PM | #18 |
Rep 9,034
How much is a GT3 and GT3-RS in Euro?
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
08-21-2010, 12:59 PM | #19 |
Rep 961
Let me offer a slightly different viewpoint on this. The GT4 is a real race car and it has a roll cage, fuel cell, etc. However, it's not legal for road use and anyone buying one signs a waiver that releases BMW from all liability. The underlying message is "we make no representations that this vehicle is safe - are we clear on that?"
I suspect that changing all the GTS body panels and greenhouse glass to plastic, as used in the GT4, would have required a new safety certification, possibly including a crash-test. Without the safety analysis and testing, BMW's liability in the event of death or injury would be enormous. Furthermore, in the absence of the roll cage it's hard to predict whether it would have even passed. In any case, the cost of the safety certification would have likely meant millions of dollars of expense that would have to be borne by the buyer. |
08-21-2010, 01:26 PM | #20 | |
Registered Sex Offender
573
Rep 4,759
Stop putting stuff like painted reflectors and premium package in your signature. You're embarrassing.
08-21-2010, 02:01 PM | #21 | |
Moderator
675
Rep 4,737
Of course, I am not an expert on crash test certifications in Europe, but from watching Top Gear, it seems that anything with wheels can go on the street |
