09-03-2010, 04:40 PM | #1 |
Putcha ang ganda...
281
Rep 5,441
suspension problem need help
ok i have been hearing suspension noises when i hit a bump. it can be front or rear.
it sounds like a clunk sound like the suspension is somewhat loose but this only happens when i hit a bump does this happen to anyone? thanks in advance sean |
09-03-2010, 04:47 PM | #2 |
Rep 3,574
isn't this normal for any car?
you go over a bump and boom... sounds normal to me
2015 Porsche 991.1 GT3 2015 F80 M3 -- Individual; Space Grey |
09-03-2010, 08:07 PM | #3 | |
Putcha ang ganda...
281
Rep 5,441
im not quite sure exactly but mine sounds more like a loose strut sound.. like when hitting a bump it sounds like metal clunking sound im not exactly sure how it sounds but its not your normal bump or small pothole. its like after you hit the bump your hear a metal to metal sound but its very light. ... SORRY GUYS IM REALLY HAVING HARD TIME TO EXPLAIN IT |
09-03-2010, 08:16 PM | #4 |
Formerly K335i
19
Rep 215
Stock suspension?
2009 E92 M3 :: Jet Black :: Fox Red Extended :: Carbon Leather :: 6MT :: JRZ RS Suspension :: RD Sport Sways :: StopTech Trophy Brakes :: Cantrell Brake Cooling |
09-08-2010, 06:56 AM | #6 |
Rep 164
Are you under warranty?
2008 E92 M3 Melbourne Red, 20" Iconz 880Z, Gintani race exhaust, HID angel eyes, 6k Interior light kit, Vorsteiner VRS lip
Car for sale thread http://www.m3post.com/forums/showthread.php?t=577829 |
09-08-2010, 07:53 AM | #7 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
I'm on my second e90 M3. Both have had a very slight clunk as I turn into the driveway and run over the 1.5 inch concrete lip at the end of the driveway with the front wheels turned. I even replaced the stock track arm bushings with Dinan bearings and still had the same noise. So I think a slight clunk over small low speed bumps is normal.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now. Why, yes. I am an abrasive bastard. |
09-08-2010, 12:32 PM | #8 | |
Putcha ang ganda...
281
Rep 5,441
yeap its exactly the same problem that i have... i guess its normal then. thanks. although i have an appointment this saturday and plus they are giving me a loaner just to check it out... kewl thanks.
09-08-2010, 02:26 PM | #9 |
Rep 534
Clunk ? is the noise like a little knock ? sometimes when you slow down to go over a pothole that you cant avoid or a speed bump ?
Well the last time i had one of thos problems was when my last car was with me for 4+ years and the rubbers/leather the engine sits on "as i was told by the BMW mechanic" dried up because of the hot weather here or because of usage. I got them changed and the car went to normal again as good as new. I would personally get it checked just in case should be nothing to worry about.
09-10-2010, 04:33 PM | #11 |
Rep 2,665
Drives: Goggomobil
I recently started to experience this "clunk" and the car is going in next week to be looked at. I went for a drive with the master tech and he confirmed the "clunck" I was hearing. We're trying to isolated the noise because I had my 6MT replaced recently under warranty in a '07 build car. I definitely think it is the front suspension. You hit a pothole and as the car settles it "clunks".
This "clunck" should be normal only if everyone is experiencing it. If only a handful are, then it is a problem or an issue.
F86 X6///
09-11-2010, 09:21 AM | #12 |
Veni Vidi Vici
89
Rep 2,750
I had a more serious clunk in the front end of my previous car at one point. The dealer said some mount somewhere had come loose. Sorry I don't have more detail. But both e90s have had a minor driveway entrance clunk that I attribute to the steering rack; but it could be something else.
09-08-2011, 02:43 PM | #13 |
Rep 628
Sorry to bring up an old thread but I am starting to experience this same sound.
Has anyone determined what it is from bring it into the dealer? I also just started another thread "Suspension Clicking" Thx
09-23-2011, 06:41 AM | #14 |
Rep 1
E92 Suspension vs. E92 M3
I am interested in Moton as my suspension upgrade. In particular the Clubsport series. When I contact Moton they said that they have the kit for the E92 M3 but that they don't have the necessary specs for the E92 335ci in this case to determine if their kit will work?
They are not sure if the suspension used on the E92 platform is the base for the M3 or if they are in any shape the same. If they were then they are confident that they can make the M3 kit work on our 335ci (sport or non-sport). Is there's anyone here that can either confirm or deny that the 335i suspension geometry and specs are the base platform for the M3 please let me know Moton is also checking with their contacts to confirm, hopefully someone with sure knowledge about both suspensions can chime in. I am sure that the M3 suspension is definitely different in settings compared to ours, but if the parts are the same then the valving etc. can be reworked. instant payday loans |
09-23-2011, 11:04 AM | #15 | |
BimmerPost Supporting Vendor
732
Rep 3,735
If nobody has tampered with your suspension at all, chances are nothing is loose. If this helps at all, I have heard this sound on some of the M3's I have seen in the shop. Same scenario, going up or down a driveway at low speeds. Each and every time it was the plastic fenders clicking and making noise since they are not hard bolted to the body and are mounted on slider tabs for heat expansion.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
