09-11-2010, 11:52 AM | #1 |
Rep 32
What is the Best first upgrade to make to the 128i?
Hello! I have saved up around $2000 to spend on my 128i (automatic). Please dont tell me i should have gotten the manual cause the car was a present(not my choice). So, what will be the best upgrade to make with around $2000???
09-11-2010, 12:07 PM | #2 |
Rep 1,552
Drives: '19 M2C | '20 100AE ND2
Depends, what are you trying to do? Make it look good? Performance?
Maybe coilovers first and have some money left over to save for wheels/tires.
2019 M2C - Alpine White - 6MT
2023 Supra 6MT - Deposit and Wait |
09-11-2010, 12:46 PM | #3 |
137
Rep 337
If you did not get xenons, then get some Depo projector headlights from Jlevi... wait about a week more or so, and the new upgraded angel eyes should be finished (they are much brighter than the stock Depo AEs).
This is what I did: Performance -BMS powerbox (yes, really works) -BMW Performance Intake Cosmetic -BMW Performance grilles -BMW Performance shifter (alcantra) -BMW metal e-brake assembly (alcantra) -BMW Performance sideskirts (still awaiting their arrival) I love the way my car looks thus far and I only look to please myself with the car's aesthetics/performance... and I'm sure I won't stop making little changes as time progresses Do what makes you happy. |
09-11-2010, 12:56 PM | #4 |
Unloved BMW Addict
86
Rep 1,185
Drives: Z3 Coupe, 3 318Ti
I have heard and seen both the BMW performance intake and exhaust. IMHO: BMW Performance Exhaust.
09-11-2010, 06:24 PM | #5 |
Rep 32
Im sorry I didnt really specify, but I really want to better my 0-60 time. So, I guess performance. On the other hand, i've heard there is nothing i can really do to make the time better. Will BMW Perf. exhaust help? or their Intake? If so, which one is better for this?
Thanks |
09-11-2010, 08:06 PM | #6 |
Rep 1,025
Drives: G08 iX3
For my 125i, the BMS powerbox knocked 0.5 seconds off my 0-60 time. It may not sound like much, but it is an improvement and it is repeatable
Intake and exhaust will give you great sound but not so much in the way of performance. The best power upgrade however would be to send your ECU to Germany and have one of the tuners there remap your ECU (e.g. wintertuning.de) - that'll give you an extra 40-50hp or so. If you want an easier local option, try oetuning which offers ~20hp via a simple plug-in device. |
09-11-2010, 08:28 PM | #7 | |
137
Rep 337
I wonder if wintertuning's tune is detectable by BMW? |
09-11-2010, 09:28 PM | #8 |
Rep 7,408
I would not be concerned about the power.wait couple years and there will be better wide range of ecu tuning/header etc. I would touch suspension for now, descent coilover or spring/shock combo. driving will be much more pleasant. after that wheels/tire maybe?
09-12-2010, 01:51 AM | #10 |
Rep 1,025
Drives: G08 iX3
Most probably yes.
It will make your car look faster. Some people want this. |
09-12-2010, 02:37 PM | #11 |
Vrooom :)
314
Rep 2,602
the only mod i have done so far and am very happy about is the injen intake! It sounds awesome : )! and if u want a better exhaust note, i suggest you do the golf tee mod
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
09-12-2010, 04:21 PM | #12 |
Rep 567
I would do the intake and exhaust. I have the M sport body kit. It is nice, but I don't know that it makes the car work any better. It all depends on whether you want your car to handle better or go faster. Which wheels do you have? Do you like them? Many wheel and tires sets are nice and quite a bit lighter than stock. Less weight on corners will give you quicker turn in and greater acceleration without any other mods.
09-12-2010, 08:59 PM | #14 |
Rep 1,040
09-12-2010, 09:43 PM | #15 | |
Rep 32
I kind of want something that will always be there (in power terms) when you push on the gas pedal...maybe a supercharger kit However, our magnesium block engines will heat up tooo quickly for that!! |
09-13-2010, 03:13 AM | #16 |
699
Rep 3,267
Drives: 2010 128i
The aero kit will certainly not help your 0-60 time, and will set you back thousands of dollars. I wouldn't waste your time with it.
I would look into the BMS PowerBox. It's supposed to remap the throttle to be more responsive, as well as make some ECU adjustments. It's debatable whether or not the tune offers any demonstrable HP or torque gains, but the more aggresive throttle remap will get you moving quicker. And it's less than $300, and is pretty much plug-and-play. That said, I think the suspension and tires are a more urgent mod, but they're also pricier and more involved.
____________________________ Last edited by Bimmer-Bob; 09-14-2010 at 06:30 AM.. |
09-13-2010, 04:27 PM | #17 |
Rep 759
Drives: 128i Coupe 6MT
Buy an E46 M3 and you're all set. Or find some way to put that beautiful 3.2L NA M-Power engine in your 128i. Aside from that, you're not going to squeeze much more out of the N52 in a truly cost-effective manner (i.e. you could put 20k into it, or you could put 20k into a different car...)
Stroker kit would also be amazing but costs a fortune! |
09-14-2010, 06:37 AM | #18 | |
699
Rep 3,267
Drives: 2010 128i
That said, I think the PowerBox sounds pretty promising and I'll probably give it a try later down the line. I would just like the go pedal to be a little more sensitive to input.
____________________________ |
09-14-2010, 11:35 AM | #19 |
Rep 759
Powerbox will give you the pedal response you're looking for. I'm not so impressed with the gains, but I definitely think it was worth it because it sharpens up the response. Thumbs up on that one.
The N52 is also used in the 130i/330i, if you can figure out what the differences are (has to do with intake and exhaust manifold I believe) you can probably get up to that range. But you'll need the new hardware and a tune as well. |
09-14-2010, 03:56 PM | #20 | |
Rep 32
Powerbox?
09-15-2010, 12:43 PM | #21 |
Rep 1,040
09-15-2010, 02:22 PM | #22 |
137
Rep 337
