09-27-2010, 12:58 PM | #1 |
549
Rep 5,695
▀▄ eas | Macht Schnell - Competition Wheel Spacer kits for BMW
In order to give your BMW a much more aggressive stance while increasing handling, we offer our line of Macht Schnell Competition Spacer Kits.
Machined from 6061-T6 aerospace aluminum, these adapters are strong as well as lightweight to limit unsprung/reciprocating weight for maximum performance on or off the track. Spacer edges are also chamfered to allow for easy installation/removal if needed. After machining, the spacers are then anodized for additional strength, anti-corrosion & wear resistance. Here is a recent article in European car: -An additional online article in European car's Tech section: http://www.europeancarweb.com/tech/e...gineering.html -Macht Schnell spacer reference thread with photos and spec details: http://www.m3post.com/forums/showthr...schnell+spacer -Macht Schnell DIY on how to properly install spacers: http://www.m3post.com/forums/showthread.php?t=272915 A wider track stance increases lateral stability as well as giving your BMW a much more aggressive appearance after installation. Spacers also are used to correct wheel gap normally seen on otherwise stock suspension setups, pushing the wheels outward - filling the fenders. Included with our Competition Wheel Spacer Kits are a full set of extended lug bolts in black OEM finish. All wheel fasteners are hardened and tempered to strength class 10.9 or 10 according to DIN/ISO standard 898 and meet the statutory requirements of all countries - including the US. Competition Wheel Spacer kit Features: - Machined from 6061-T6 aerospace aluminum - Chamfered edges allows installation & removal quick and easy - Black anodized finish for additional strength and corrosion/wear resistance - Improve handling by reducing body roll with a wider wheel base - Included black extended-length corrosion-resistant wheel fasteners Macht Schnell - Competition Wheel Spacer kit for BMW - 03mm http://www.europeanautosource.com/pr...oducts_id=2197 Macht Schnell - Competition Wheel Spacer kit for BMW - 05mm http://www.europeanautosource.com/pr...oducts_id=2198 Macht Schnell - Competition Wheel Spacer kit for BMW - 10mm http://www.europeanautosource.com/pr...oducts_id=2199 Macht Schnell - Competition Wheel Spacer kit for BMW - 12mm http://www.europeanautosource.com/pr...oducts_id=2200 Macht Schnell - Competition Wheel Spacer kit for BMW - 15mm http://www.europeanautosource.com/pr...oducts_id=2201 Macht Schnell - Competition Wheel Spacer kit for BMW - 18mm http://www.europeanautosource.com/pr...oducts_id=2202 Models Supported: 2008+ 1-series 1992+ 3-series, including M3 (e36, e46, e90, e92) 2004+ 5-series, including M5 (e60) 2005+ 6-series, including M6 (e63, e64) 2004+ X3 (e83) 2000+ X5 (e53, e70) 2003+ Z4, including M-Roadster/Coupe (e85) 2001-2003 Z8 1996-2002 Z3, including M-Roadster/Coupe All sizes are currently in stock and available for immediate shipment. |
11-15-2010, 10:53 AM | #6 |
Rep 2,438
11-15-2010, 02:02 PM | #7 |
549
Rep 5,695
01-05-2011, 04:43 PM | #16 | |
549
Rep 5,695
It's a new year, so give your car a new look with a wider stance with Macht Schnell Spacers!
01-05-2011, 05:03 PM | #17 |
Rep 3,177
i'm interested in a set of front and rear for my 135i. i don't know the correct size, however, for my setup:
stock 261 wheels lowered on koni shocks, h&r springs i'd like the widest possible without causing any rubbing or needing to roll fenders. can you assist? thanks in advance |
02-06-2011, 07:05 PM | #22 | |
Rep 2,080
http://www.europeanautosource.com/pr...oducts_id=2198 In stock? Last edited by scott135i; 02-06-2011 at 09:41 PM.. |
