09-30-2010, 05:51 PM | #1 |
You live by the sword...
216
Rep 8,244
Double Din solution?
Has anyone seen a double din solution for the 1er (w/out nav)?
The AC controls would need to be relocated to the lower compartment, like the E46 with nav....I'm guessing there is nothing like this out there.... |
09-30-2010, 05:54 PM | #2 |
216
Rep 8,244
Something like this....I'm guessing it would have to be a custom job...
http://www.1addicts.com/forums/showt...ght=double+din |
09-30-2010, 07:16 PM | #3 |
Rep 189
Drives: '13 Z4 sDrive35i DCT
looks like Metra only has a single DIN solution so far:
https://metradealer.com/files/products/INST99-9306B.pdf |
09-30-2010, 09:01 PM | #4 |
Rep 161
check this out tho.....
https://metradealer.com/api/vfg/view...ct/id/95-9306B Fit says 3 Series only right? how come the 1 series one says fits "1 and 3 series" https://metradealer.com/api/vfg/view...ct/id/99-9306B (click info tab) if the 1 series fits both shouldnt the 3 series also fit both? who wants to test out this theory?
2010 BMW 135i
09-30-2010, 09:18 PM | #5 |
Rep 189
I'd just call Metra and ask them directly...
10-01-2010, 11:00 AM | #6 |
216
Rep 8,244
It doesn't cost that much....I'd be willing to test it out once i'm ready to go the double din route...quick question though, where would the buttons go? (i.e. the row of buttons directly beneath the ac controls).
10-01-2010, 11:11 AM | #7 |
216
Rep 8,244
...something like this: https://metradealer.com/api/vfg/view-product/id/98-9306
Are the buttons used for anything? I will have HK, but no heated seats |
10-08-2010, 10:37 AM | #9 |
216
Rep 8,244
I just called them, spoke with both customer service and tech support.....they weren't very helpful. They simply said that it won't fit, but couldn't give me any details since they don't have much information on the 1 series.
10-08-2010, 10:41 AM | #10 |
216
Rep 8,244
I think the bigger issue would be finding out how much space is available behind the dash to see if a double din would even fit back there. I know that for my e46, I had to cut and modify the ac vents behind the dash in order to make it fit....hopefully that's not the case here.
10-08-2010, 11:41 AM | #11 |
216
Rep 8,244
Here's another 3 series double din made by rich: http://mybimmer.net/E9x_doubledintrim.htm
10-12-2010, 07:55 AM | #12 | |
Rep 1,375
-Nick |
10-13-2010, 12:33 PM | #13 |
Rep 246
I'm also pretty interested in finding out more about a double-din solution. I don't have the heated seats so my panel below the HVAC controls is empty. A double din solution and moving the HVAC controls down a slot would be beyond awesome.
10-14-2010, 12:32 AM | #14 |
Rep 2,757
Drives: 2017 Audi A4
www.crutchfield.com
fits any and all products of any brand name range to your specific car, also sells the PAC hardwares, etc. to utilize steering wheel controls, never went with another site other than theirs for car audio shitz |
10-14-2010, 10:35 AM | #15 | |
216
Rep 8,244
10-14-2010, 10:44 AM | #16 |
Rep 246
10-14-2010, 10:53 AM | #17 |
216
Rep 8,244
^^^ yeah...I'm thinking if enough of us request it from Rich (from e46fanatics), he might be willing to build one for the 1 series.
10-14-2010, 03:32 PM | #19 |
Rep 2,757
Why again dyou need a double?? Crutch has plenty of receivers that fit the 1ers when you pop out the factory headunit. Why double?
10-14-2010, 03:56 PM | #20 |
Rep 246
Because Exhibit A looks so much nicer & cleaner than Exhibit B...
Exhibit A: http://www.mybimmer.net/E9X_Double_Din/DSC02460.JPG Exhibit B: http://www.e90post.com/forums/attach...1&d=1202441713
2022 Tanz Blue M440i RWD Coupe - Soon™
2011 Crimson Red 135i - SOLD 2008 Jet Black 135i - SOLD |
10-14-2010, 04:04 PM | #21 |
216
Rep 8,244
10-14-2010, 04:28 PM | #22 |
Rep 2,757
In regards to both of you, first off, the exhibit B photo shows a diff 1er interior setup, and also has the gay ass flip up big screen, i am speaking of a regular 1 slot receiver with everything you need mind the nav shit cuz thats not important to me, I have a garmin and it works fine, dont need to spend the extra hundreds of dollars on permanently installed nav..
I think only those who NEED the all in on nav receiver option permanently installed would have an issue with there being no dbl din option elsewhere. Me, if I wanted to change up receivers, which I dont, Id just go with a single with PAC controls to use the steering wheel. Bingo. I would consider it if companies like JL, etc. made a custom sub housing that fit the 1er, much like the JL stealthbox I had for my GTI, fit the left side of the rear inside the hatch perfectly, which then allowed me to mate it up with a amp bolted on the other side and a cd changer mapped to the receiver I had. So until someone makes a kit or a sub kit that fits the 1er perfectly like that, ill stick with the factory setup. Its not great for sure, but its not bad either. |
