10-04-2010, 04:39 AM | #1 |
Rep 1,311
Installing rear RD Roll-bar - what's involved
Fella's,
I'm thinking of going Stage 1 Dinan and F/R RD roll-bars. But before I go that route, I read somewhere that the rear bar involves dropping the sub-frame. Has anyone done it themselves? What's involved and any special tools needed? I have access to a lift and a shop but has basic tools so if there is anything special required, that would be a bad time to find out. Also, is it worth the trouble? Or better to just go with the Dinan stg 2 which comes with the Dinan front Roll-bar? Thanks, |
10-04-2010, 10:42 AM | #2 |
Rep 700
Just go Dinan Stage 3 while its on sale. I do not recommend mixing performance suspension parts that surely were not made for each other.
They could work nicely together, but likely they will not.
I apologize for spelling mistakes up front, they are a result of multitasking.
10-05-2010, 08:03 PM | #5 |
Moderator
675
Rep 4,737
It takes a lot of labor, probably 4 hours. You need to remove the exhaust, disconnect the brake lines, disconnect the differential, disconnect the shock, and finally you can unbolt the sub frame.
10-05-2010, 11:45 PM | #6 | |
Rep 3,668
lot of work, i was planning on getting rd sways, however looks like im going to pass |
