BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      10-06-2010, 03:20 PM   #1
mpardun
CO 14GIPPR
mpardun's Avatar
Drives: '11 e90 ///M3
Newbie ?: Why does BMW use a single piston brake?
I apologize if this has been asked and answered...
I am far from an expert, but with all serious road and race cars using 4-6 piston brakes. It stands to reason that using a 1 piston brake setup may make sense for a mainstream production vehicle, but why would BMW choose a 1 piston option for it's supposed performance car?
Please something aside from cost (as all other German makers I am familiar with use multi-piston brakes).
Just curious...as I await my 2011 build and contemplate aftermarket wishlists.
      10-06-2010, 04:00 PM   #2
elh0102
Drives: 2009 335i coupe
Well, cost is probably the biggest reason, like it or not. But, I wouldn't worry about it. Folks get too concerned about the number of pistons, but the quality and stiffness of the caliper is more important. The stopping effectiveness is mostly dependent on the rotor and pad sizes (swept area). And the fade resistence is mostly the determined by cooling, which is very related to the internal design of the rotor, as well as additional cooling ducts. Under extreme conditions, as in racing, multiple pistons should produce more evenly distributed pad pressure, resulting in less pad taper and probably longer dependable performance before fading. But with appropriate pads and fluid, the stock M3 brakes are very good, even for casual track use.
      10-06-2010, 04:25 PM   #3
rob612
rob612's Avatar
Drives: e92 - m3
VERY well said!
      10-06-2010, 06:43 PM   #4
JCtx
Drives: No BMW yet
Only reason is cost; What else? They're not better than multi-piston calipers. And not nearly as sexy either . But they're 100% effective on the street. And somewhat effective on the track. And yes, better pads and fluid help with the latter.
      10-07-2010, 12:34 PM   #5
AP Racing - Chris_B
Brake Maven
AP Racing - Chris_B's Avatar
Drives: E34 540i/6, others
Like others have already said, it's the cost. I will say that Ate (Continental) makes about the stiffest and best sliding caliper production brakes you will find. In some cases, I prefer them to the low cost, OE-style fixed calipers like those found on many "value proposition" sportier cars. However, as good as they are compared to other sliders, they still do not compare to well-engineered multiple piston fixed calipers. All BMW Motorsport vehicles that I've seen come from the factory with fixed calipers (AP Racing).
Chris
      10-07-2010, 03:08 PM   #6
swamp2
swamp2's Avatar
Drives: E92 M3
+2, very well said. I've posted similar comments over and over in many brake threads.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      10-07-2010, 04:23 PM   #7
AP Racing - Chris_B
Brake Maven
I also agree with much of elh1002's comments, IF one does not factor into the equation brake feel and driver confidence. Many drivers who like to experience the M3 for all that it is worth cannot easily do that. At the level the M3 represents, many drivers expect more from their brakes, regardless if the OE sliders can be band-aided to handle a bit more temperature or what the one-time panic 60-0 stopping distance is. Pads, tires, springs, dampers and their respective tuning can be worked in synergy to shorten stopping distances, if the driver is only concerned about numbers. If so, then the OE brakes are fine for many.
However, those that have really driven high-performance brake systems are typically not fully satisfied with BMW's selection due to its lack of feel and feedback at the limit of tire adhesion. For them, it is all about control. It is for those drivers that there are other choices out there, whether they seriously track the car or not.
Chris
      10-07-2010, 04:25 PM   #8
rzm3
Moderator
rzm3's Avatar
675
Drives: E92 M3
Well, we can soon say good bye to the sliders on M3 as the next gen M cars should all have fixed and multi piston calipers (as shown on the new M5 spy shots)
      10-07-2010, 11:07 PM   #9
jml
jml's Avatar
128
Drives: X5M, GT3RS, GT4
Gauging by the recent trends at ///M (turbos, 5000lb+ cars), that does not indicate better performance. Pretty, yes...
m3post
